Sure @Antoine, Thank you for trying to help me!
Audirvana Mac Version 3.5.41 (3571)
Registered to Nicolas Crespo
AUTO: /Volumes/Nico 5TB/Audirvana
iTunes/Music library synchronization: last synchronized on Wed Sep 23 20:15:38 2020
Library database path: /Users/nicocrespo/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 12188MB
Exclusive access: Disabled
DX7s
Model UID:DX7s:152A:8750
UID:AppleUSBAudioEngine:Topping:DX7s:14544000:1
ID 0x45 DX7s Manufacturer:Topping
Model UID:DX7s:152A:8750 UID:AppleUSBAudioEngine:Topping:DX7s:14544000:1
Stream ID 0x46 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 4
Device #0: ID 0x4a LG HDR 4K Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:10001:0:{6D1E-7707-000021C1}
Device #1: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:57 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #2: ID 0x3a USB Advanced Audio Device Manufacturer: C-Media Electronics Inc. Model UID: USB Advanced Audio Device:0D8C:0022 UID: AppleUSBAudioEngine:C-Media Electronics Inc.:USB Advanced Audio Device:14520000:1
Device #3: ID 0x45 DX7s Manufacturer: Topping Model UID: DX7s:152A:8750 UID: AppleUSBAudioEngine:Topping:DX7s:14544000:1
