I am streaming using an Arcam ST60 and seem to have an interference noise issue amongst some others.
I launch the programme on a Windows 10 Pro machine and use my IPad as a remote. When I pause or stop the music I can hear a hum in the speakers and if I scroll the Windows PC app page up and down I get a scratching noise through speakers. If I shut the application in Windows PC the hum and scratching noise immediately stops. Don’t want to commit if i’m having these issues, any ideas ?.
Hello @MarkR,
Can you send me a copy of the “Debug Info” while you have the issue? You can get it in Audirvana Settings>General>Debug Info
Hello Damien,
Because i’m a new user it says I can’t post more than 5 links in a post ???
I changed your settings, you should now be able to post it.
Audirvana 3.5.43
AUTO: E:\Music
Library database path: C:\Users\User\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Living Room speaker Model UID:Harman Luxury Audio Living Room speaker UID:uuid:6dda07ff-1388-46e9-9328-6a3da042c4b1
UPnP device at http://192.168.0.25:45871/6dda07ff-1388-46e9-9328-6a3da042c4b1.xml
Living Room speaker Manufacturer:Harman Luxury Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/flac:
http-get::audio/m4a:
http-get::application/ogg:
http-get::audio/wav:
http-get::audio/x-m4a:
http-get::audio/x-dsf:
http-get::audio/x-wav:
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::text/xml:
http-get::audio/x-dff:
http-get::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Can play native DSD: Yes
NrTracks: 1
MediaDuration: 0:06:55
CurrentURI: http://192.168.0.29:49152/audirvana/audio_0_0.wav
CurrentURIMetadata:
dc:titleThe Ascent Of The Ascended</dc:title>
dc:creatorTim Burgess</dc:creator>
upnp:artistTim Burgess</upnp:artist>
upnp:genreAlternatif et Indé</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/da/q7/y8gf4uvs1q7da_600.jpg</upnp:albumArtURI>
upnp:albumAscent Of The Ascended</upnp:album>
nextURI: http://192.168.0.29:49152/audirvana/audio_1_1.wav
505 (Live)
Arctic Monkeys
Arctic Monkeys
Alternatif et Indé
http://static.qobuz.com/images/covers/6a/f2/h370r1d4nf26a_600.jpg
505
1
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 Living Room speaker Harman Luxury Audio http://www.arcam.co.uk/ ARCAM ST60 http://www.arcam.co.uk/ e112825d-768a-4c99-9eb4-e5c1e317362d uuid:6dda07ff-1388-46e9-9328-6a3da042c4b1 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.0.25:80/ DMR-1.51UPnP devices found : 2
Device #055FZ950_Series UID: uuid:4D454930-0100-1000-8001-80C755651115 Location: http://192.168.0.17:55000/dmr/ddd.xml
Device #1Living Room speaker UID: uuid:6dda07ff-1388-46e9-9328-6a3da042c4b1 Location: http://192.168.0.25:45871/6dda07ff-1388-46e9-9328-6a3da042c4b1.xml
Max. memory for audio buffers: 6434MB
Local Audio Engine:WASAPI
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{bde1bf16-836f-42ed-b6f3-48dae61ac214}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Panasonic-TV (Intel® Display Audio) Manufacturer: Model UID: Panasonic-TV (Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{fb49e9de-e5ba-4281-a5d5-5817ddb2dc59}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Have you tried to reproduce the issue while you select the speaker of your computer?
No I haven’t as I have no speaker set up for it.
I have just been listening to music and the noise starts with a scratching then after time it sounds like a distant jack hammer coming through speaker, sometimes it’s not there and then it starts again. When I command the software with the mouse you can hear it change pitch or even disappear. When it gets quite loud I close Aurdivana software and immediately noise disappears. Such a shame as the sound quality from my ripped cd’s is fantastic.
I have also had this error message three or four times.
Audirvana has exited unexpectedly
A miniDump file has been generated.
Do you want to close explorer ?
Another issue is I play a hi-res album from Tidal or Qobuz, it says on the left at the bottom 24/196 but output on right is 24/48 and same on streamer.
If I go to my musiclife app on my IPad and play the same album, on the streamer display I see MQA before the title which I don’t see and it says 196 not 48 as through Audirvana.
Correction, I meant 24/192
Same album played through Audirvana would say 48KHz.
Is this on Tidal with MQA file?
Yes. I can see a green dot on software through Audirvana on the left but when you look by the speaker on the right it says 24/48 the same as on my Arcam. Use the Arcam app musiclife and my unit displays MQA above artist and shows 192.
Check with Arcam if the MQA is supported over UPnP.
Do you know if your Arcam is a MQA Decoder or Renderer?
This is from Arcam blurb saying it is a decoder.
The Arcam ST60 is a high-performance streaming player that features a full MQA decoder, which enables you to play back MQA
In UPnP you need to set your Arcam as Decoder, otherwise you won’t get the full unfold of MQA. To do it you need to go in the audio output settings and in the audio device capacity, you need to selected MQA Decoder.
Yes I had already done that as it hadn’t recognised it as one.
Volume control: No
