Audirvana 3.5.12
AUTO: E:\gio_b_music
Library database path: C:\Users\giovanni\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1710MB
Local Audio Engine:WASAPI
Model UID:
UID:
Device: 2ch 24bits Integer, 6 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
SPDIF Interface (audiophilleo2 MKII v1.37 SN02315) Manufacturer:
Model UID:SPDIF Interface (audiophilleo2 MKII v1.37 SN02315) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{a07a7331-0a20-4750-bba7-ddff9c48e62a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 44.1kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 48kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 88.2kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 96kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 176.4kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 192kHz
Device #0: SPDIF Interface (audiophilleo2 MKII v1.37 SN02315) Manufacturer: Model UID: SPDIF Interface (audiophilleo2 MKII v1.37 SN02315) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a07a7331-0a20-4750-bba7-ddff9c48e62a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (High Definition Audio Device) Manufacturer: Model UID: Speakers (High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{1893b8f0-043c-404b-bd90-8c3e3f3b60fc}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0JPLAY FEMTO UID: uuid:JPLAY192.168.1.43-MediaRenderer Location: http://192.168.1.43:48167/JPLAY192.168.1.43-MediaRenderer/Upnp/device.xml
