Tks 1000 any way.
Giovanni.
Unfortunately you will need to use software volum control if you want to play 16/44 music in Audirvana while you are connected in SPDIF to your audiophilleo.
Hi ,for all the problems I had ,I wasn’t able to full test Audioirvana, may I have some more time to try it?
Thanks in advance Giovanni.
That means is not possible ?
Tks Giovanni.
