Hi @TribecaMikey
Your settings are identical to mine.
My Spotlight fails to open when I’m playing a file. Upon stopping (unlocking the music) Spotlight opens normally (Command + Spacebar).
Please copy and paste your debug so the experts can perhaps identify your issue.
Regards
Phil
UPDATE
I double checked… Spotlight still operates even although my settings are to stop Spotlight during playback.
DEBUG FOLLOWS
Audirvana Origin 2.5.18.1 (20519)
macOS 14.6.1 ARM64 with 8GB physical RAM
Connected account of : Philip Johnson
Sync list: 2 folders
AUTO: /Volumes/MusicSSDT7/AO-SSD-Music-T7
AUTO: /Volumes/MusicSSDT9/AO-SSD-Music-T9
Library database path: /Users/philipjohnson/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 51583
Font size: large
Library
My Music
Startup view: Library: Albums
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
PS Audio PS Audio USB Audio 2.0 Output
Model UID:PS Audio USB Audio 2.0:2616:0110
UID:AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:2400000:1
Active Sample Rate: 96kHz
Sample rate limitation: 352.8kHz
Sample rate switching latency: 1.5s
Selected device:PS Audio USB Audio 2.0 Output
Manufacturer: PS Audio
Model name: PS Audio USB Audio 2.0 Output
Model UID: PS Audio USB Audio 2.0:2616:0110
UID: AppleUSBAudioEngine:PS Audio :PS Audio USB Audio 2.0:2400000:1
USB Vendor ID: 0x2616
USB Product ID: 0x0110
ID 0x4e
7 available sample rates up to 352800Hz
Max volume alert: Disabled
DSD via PCM 1.1
Stream ID 0x4f 2 channels starting at 1
21 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
28 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Device #0: ID 0x4e PS Audio USB Audio 2.0 Output
Device #1: ID 0x48 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 : BRAVIA KDL-32EX720
UID: uuid:00000000-0000-1010-8000-4CE676BC4AD6
Manufacturer: Sony Corporation
Model name: KDL-32EX720
Chromecast devices found : 1
Device #0: Living Room TV
Model name: Chromecast HD
