Output to 24 bit instead of 32
I have tried flipping the dac input radio button to 24 but I still play at 32 no matter what. My chain is NUC>SOTM USB Reclocker>SRC-DC (USB to dual BNC)> Chord.
The reason I want to output to 24 is according to SRC DX it wants 24 bit, I am guessing audrivana is seeing the SOTM reclocker and sending 32 but I dont want the 32 to 24 conversion happening between the USB reclocker and the SRC DX, I would rather the computer do it and keep the sample rate maintained all the way through.
I tried looking at not another dither but I could not get it working.
Any tips would be much appreciated. TY
Jason
Audirvana Studio 2.6.3 (20603)
Windows 11 (22621) with 16GB physical RAM
Connected account of :
Available network interfaces:
Ethernet 2 ({fc942996-50c1-4cd8-87f4-0ec77d705f24}) is PUBLIC
Active profile types: all
Private profile:
Firewall: disabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: disabled
Inbound: blocked
Outbound: allowed
	VST3 plugin #0: C:\Program Files\Common Files\VST3\HLConvolver.vst3
		ClassID: ABCDEF019182FAEB4D616E754F6E6765
	VST3 plugin #1: None
	VST3 plugin #2: None
	VST3 plugin #3: None
r8brain custom frequencies
Bandwidth = 74.783%
Stop band attenuation 125.381dB
Phase minimum phase
SW volume control: ON
AUTO: C:\Users\Admin\Music
Library database path: C:\Users\Admin\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 1982
Listening on 172.16.0.50 on port 50695
TIDAL: Connected as HiFi Plus
Max. memory for audio buffers: 10552MB
OCTA-CAPTURE
Model UID:OCTA-CAPTURE
UID:OCTA-CAPTURE
Sample rate switching latency: 5s
Limit bitdepth to 24bit: ON
Selected device:Speakers (SRC-DX)
Manufacturer: Microsoft
Model name: SRC-DX
Model UID: USB\VID_2FC6&PID_6013&REV_0201&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{426e46c2-1d27-4e14-8b6a-33145a9efc66}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x2fc6
USB Product ID: 0x6013
Kernel Streaming capable
Max volume alert: Disabled
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Device #0: Speakers (SRC-DX)
Model name: SRC-DX
UPnP devices found : 1
Device #0: [LG] webOS TV OLED77C1PUB
UID: uuid:76379775-f0e9-feda-bbc8-75bd53b881ff
Manufacturer: LG Electronics.
Model name: LG TV
i’m guessing you see 32/xx on the right of the main window…
Audirvana decided to show always your DAC bit depth on the right, not the output.
but if you see 24/xx on the left it is outputting 24/xx… if you limit to 24 bit it is 24 going out.
the software just put zero padding to go to 32, no change in sound or upsampling done…
you are not the first coming here asking about that :slight_smile: Audirvana decision
Hmm thanks for that. It does seems strange, it sure looks like its outputting 32. I think most people care to know for sure what it is actually outputting rather than what the DAC is capable of. Certainly both pieces of info would be best to clear up any confusion.
Would that padding affect pass through devices such as the SRC which labels itself as compatible with only 24?
Not good enough to answer that… it put 8x0 at the end to show 32bits @Antoine ?
Me too, Audirvana decision :grinning:
If you click on the wheel to the right of your Output Device (DAC) there is an option that I have highlighted to select that only 24 Bits be output to the DAC, rather than 32.
Hope that helps.
Nope. All that Audirvana does if it changes bit levels (16 to 24, or 24 to 32) is ā€œzero padding.ā€ As RunHomeSlow says, this just means putting zeroes in the lowest bit registers. It doesn’t affect anything, any more than writing ā€œ1.00000000ā€ instead of ā€œ1ā€ affects the quantity. And neither does the reverse, such as when a 24-bit device is in the chain - that’s just changing ā€œ1.00000000ā€ back to ā€œ1ā€ again. No dither involved either way.
