Audirvana worked with no issues so far. I used the 3.5 version whit Classe Sigma SSP UPNP. Now in 3.5.2 version once you start a playback you cant pause it. I can advance to next track or previous but no Pause using the Audirvana remote.
I have the same issue on a Mac, no pause function using the media keys, space bar or Audirvana remote. Please see my post:
The issue is still there with 3.5.28.
Regards, Uli
Hello @Workaholic, Can you send me a copy of the “Debug Info” while you are connected to your DAC? You can get it in Audirvana Settings>General>Debug Info
Audirvana 3.5.2
Phase = 73
AUTO: D:\Audio Video\ape-flac
Library database path: C:\Users\Marton Sabli\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Sigma SSP Model UID:B&W Group Ltd Sigma SSP UID:uuid:5f9ec1b3-ed59-1900-4530-d81ede21970f
UPnP device at http://192.168.1.48:8080/description.xml
Sigma SSP Manufacturer:B&W Group Ltd
Volume control: No
http-wavetunes::audio/x-ms-wma:*
http-get::audio/x-caf:
http-get::audio/x-aiff:
http-get::audio/aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
2 ch Integer PCM 24bit big endian 44.1kHz
2 ch Integer PCM 16bit big endian 88.2kHz
2 ch Integer PCM 24bit big endian 88.2kHz
2 ch Integer PCM 16bit big endian 176.4kHz
2 ch Integer PCM 24bit big endian 176.4kHz
2 ch Integer PCM 24bit big endian 48kHz
2 ch Integer PCM 16bit big endian 96kHz
2 ch Integer PCM 24bit big endian 96kHz
2 ch Integer PCM 16bit big endian 192kHz
2 ch Integer PCM 24bit big endian 192kHz
NrTracks: 1
MediaDuration: 0:07:46
CurrentURI: http://192.168.1.4:49152/audirvana/audio_0_2.aif
CurrentURIMetadata:
dc:titleSerenade In G Major: Eine Kleine Nachtmusik, K. 525: I. Allegro</dc:title>
dc:creatorThe English Concert feat. Andrew Manze</dc:creator>
upnp:artistThe English Concert feat. Andrew Manze</upnp:artist>
upnp:genreClassical</upnp:genre>
upnp:albumArtURIhttp://192.168.1.4:49152/audirvana/artwork_0_3.jpg</upnp:albumArtURI>
upnp:albumMozart: Night Music</upnp:album>
nextURI: http://192.168.1.4:49152/audirvana/audio_1_3.aif
Serenade In G Major: Eine Kleine Nachtmusik, K. 525: II. Romance: Andante
Classical
http://192.168.1.4:49152/audirvana/artwork_1_4.jpg
Mozart: Night Music
2
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions LastChange string TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:1 SeekOnPaused,WHA urn:schemas-upnp-org:device:MediaRenderer:1 Sigma SSP B&W Group Ltd Sigma Surround Sound Processor Sigma SSP Sigma SSP D81EDE21970F uuid:5f9ec1b3-ed59-1900-4530-d81ede21970f 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-smsc-com:service:X_WholeHomeAudio:1 urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl urn:tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.1.48UPnP devices found : 3
Device #0SCHMAUG UID: uuid:3ea09125-b456-4bc5-b840-0b45337e678c Location: http://192.168.1.4:52101/DeviceDescription.xml
Device #1Sigma SSP UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede21970f Location: http://192.168.1.48:8080/description.xml
Device #2VIERA ZT60 Series UID: uuid:4D454930-0100-1000-8001-8CC121F6E95D Location: http://192.168.1.10:55000/dmr/ddd.xml
Max. memory for audio buffers: 1340MB
Local Audio Engine:WASAPI
Device #0: Speakers (Classe Sigma SSP Audio) Manufacturer: Model UID: Speakers (Classe Sigma SSP Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3276221e-fe30-420e-85a6-4f5b47c71ba7}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Class SSP801 (NVIDIA High Definition Audio) Manufacturer: Model UID: Class SSP801 (NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0a2dd2f3-9e67-4c01-bc87-327e148204ce}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Hello @Workaholic, we have experienced this issue for Mac and the fix for both version (Mac/Windows) will be live in an upcoming update of Audirvana.
Thank you! Will report back once tested.
