Play / Pause / Skip Track Bluetooth Sony WF-1000XM4
Hello
I’ve purchased “Audirvana Origin” a week back and started exploring it. It’s UI is good and also feature rich. However it also has it’s own issues which are below.
1. With my " Sony WF-1000XM4 " touch controls ( When i touch the earphones ) like " Play / Pause / Skip Track " are not working. Not sure Why? it is a basic expectation. It is not pausing when i use them, instead some Youtube Video from my browser is played / paused while Audirvana doesn’t respond to them.
2. When i click on “Album Art” from Left Lower Bottom Corner " Audio Scan " window is opening up. But INDIA has too many languages and we hear songs from at least 4 to 5 languages and Albums prior to 1980’s mostly will not be having " Album Art ", in such case how to launch the " Audio Scan " screen on track without Album Art?
3. I am using " Mac OS Sonoma 14.2 " and often times it is hanging and kept giving a message about being online and offline, if i get the error next time, i will attach the screenshot here.
Please suggest. BTW, I am using " Audirvana Origin 2.5.7 "
Thanks.
Can you send us a copy of the “Debug Info” when you have this behavior? You can get it in Audirvana Settings>My account
You need to click on this icon on the player:
And then click on the switch button at the top left of the window:
Hi @Antoine
Please find the attached Debug Report.
When I manually clicked “Play” Button on a track from “Audirvana” it is playing it and after a while, when i tap my Sony right earphone to “Play / Pause” the track, it is opening " Apple Music " app, instead of effecting the track that is being played from “Audirvana”.
That is very strange & frustrating.
Audirvana Origin 2.5.7 (20507)
macOS Version 14.2 (Build 23C64) with 16GB physical RAM
Connected account of : Rajesh D
AUTO: /Volumes/AUDIO/
Library database path: /Users/rajeshd/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
/Volumes/AUDIO
Deep Synch: yes
Intializing
Listening on 127.0.0.1 on port 50582
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Apple Inc. SONY
Model UID:de1 54c
UID:88-C9-E8-14-14-D3:output
Hog Mode is on
Selected device:SONY
Model name: Apple Inc. SONY
Model UID: de1 54c
UID: 88-C9-E8-14-14-D3:output
ID 0x74
2 available sample rates up to 44100Hz
16000
Audio buffer frame size : 14 to 1024 frames
Max volume alert: Disabled
Stream ID 0x75 2 channels starting at 1
2 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 16kHz
2 physical formats
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 16kHz
Device #0: ID 0x74 SONY
Model UID: de1 54c
Device #1: ID 0x48 iMac Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. iMac Speakers
Hi @Kenemi, I think it’s something linked to how MacOS works as on my end I have the same behavior whatever the device I use with Bluetooth. I will ask Damien for confirmation if we can do something about it or not.
If I’m not mistaken, there is a setting ‘mediakeys’, this must be enabled. When Audirvana is active, media keys control Audirvana. This has been a ‘challenge’ for a long time because it does not work well with all hardware. While all kinds of other software make this work. I created a script for my Hegel media keys that captures the commands and sends them to Audirvana. Then it does work.
why should I subscribe if it haven’t been fixed in more than a year? no such issues using Vox. they did it like this.
