Playback stops during a track
Hello,
I’m experiencing playback interruptions while listening to the radio or a song.
I have to press pause for the music to resume.
I’m using Audirvana Studio with Gentoplayer installed on a fanless NUC with an i7 processor and 16GB of RAM. My player is a Gustard S26 and my DAC is a Holo Cyan2.
In the evening, I leave Audirvana playing the radio to break in the player, but in the morning, the music stops.
I don’t understand what could be causing this ?
Is Gentooplayer supporting Audirvāna in its framework?
Interruptions during playback
In case your playback is not stable and you get interruptions during playback or tracks that do not go to the next track, there are settings to enable in Audirvāna settings:
  • Go into your audio output settings and click on the steering wheel next to your device name:
  • Enable this option:
  • Try again to play your track
Note: if you still ahve issue after doing this, please reastert your router or try usngin ethernet connection if you use WiFi wiht your device.
How to troubleshoot UPNP connection?
For help from the community and support team, please paste your debug information here in the posting.
Does this only happen when you leave music playing through the night?
When you say “the music stops,” do you mean it has stopped sometime in the night, or it stops in the middle of a track while you are listening in the morning?
Hi Jud
It stops when I leave music playing all night; in the morning there’s no sound.
It can stop mid-song or at the very end of a track without skipping to the next one.
Last night I was listening to Gregory Porter’s album Be Good, and the music froze at the very end of the track. I had to press pause to restart it and get it to play to the next track.
Hi
Here’s a copy of my debug info after a playback interruption while listening to an album on Qobuz. The playback stops at the same point, I have to press pause to restart it.
Audirvana Studio 2.11.7
Running on ASUSTeK COMPUTER INC. NUC13ANK
Linux 6.12.67-x86_64-GentooPlayer-ST-RT x86_64 x86_64 with 30.9GB physical RAM
Connected account of : LOIC GISQUET
LOADING/DECODING:
Max audio buffer size: 2012MB
Internal EQ: OFF
Max allowed volume: 0
AUTO: /media/ssd/Music
Sync folders at startup: YES
Sort and display order: en
Library database path: /root/.local/share/audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 9937
Listening on on port 33063
TIDAL: Connected as PREMIUM
Font size: regular
Language: Français
Ma Musique
Streaming
Radios
Podcasts
Startup view: Ma Musique : Albums
Number of paired remotes: 1
Active method: UPnP
eth0
Preferred device: [UPnP] S26-UPnP/AV Model UID:JF Light Industries UpMPD UID:uuid:3a54e941-c644-d275-c112-78e996ba1114
Currently playing to UPnP device at 32 bits 44.1kHz
Selected device:S26-UPnP/AV
Manufacturer: JF Light Industries
Model name: UpMPD
Model UID: JF Light Industries UpMPD
UID: uuid:3a54e941-c644-d275-c112-78e996ba1114
UPnP device at http://192.168.1.150:49152/uuid-3a54e941-c644-d275-c112-78e996ba1114/description.xml
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get:
:application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::application/vnd.apple.mpegurl:
http-get::application/x-mpegurl:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 32bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
2 ch Integer PCM 32bit little endian 768kHz finite length
2 ch DSD 8bit little endian in 8bit chunk 22579.2kHz finite length
NrTracks: 1
MediaDuration: 0:04:54
CurrentURI: http://192.168.1.50:49152/audirvana/audio_f_23.wav
CurrentURIMetadata:
dc:titleMy Foolish Heart</dc:title>
dc:creatorBill Evans Trio</dc:creator>
upnp:artistBill Evans Trio</upnp:artist>
<upnp:author role=“Composer”>Victor Young</upnp:author>
upnp:genreJazz</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/70/29/3610153652970_600.jpg</upnp:albumArtURI>
upnp:albumWaltz for Debby (Original Album Plus Bonus Tracks)</upnp:album>
nextURI: http://192.168.1.50:49152/audirvana/audio_f_25.wav
nextURIMetadata:
dc:titleWaltz for Debby (Take 2)</dc:title>
<upnp:author role=“Composer”>Bill Evans</upnp:author>
PlayMedium: HDD
Current transport actions:
Next,Previous,Pause,Stop,Seek
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 S26-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.9.0 libupnpp 0.26.7 mpd 0.23.5 image/png 64 64 32 /uuid-3a54e941-c644-d275-c112-78e996ba1114/icon.png uuid:3a54e941-c644-d275-c112-78e996ba1114 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-3a54e941-c644-d275-c112-78e996ba1114/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-3a54e941-c644-d275-c112-78e996ba1114/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-3a54e941-c644-d275-c112-78e996ba1114/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-3a54e941-c644-d275-c112-78e996ba1114/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-3a54e941-c644-d275-c112-78e996ba1114/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-3a54e941-c644-d275-c112-78e996ba1114/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-3a54e941-c644-d275-c112-78e996ba1114/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-3a54e941-c644-d275-c112-78e996ba1114/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-3a54e941-c644-d275-c112-78e996ba1114/evt-urn-schemas-upnp-org-service-ConnectionManager-1
UPnP devices found : 2
Device #0: Marantz CINEMA 70s
UID: uuid:9c304e0e-0f7b-1fb1-0080-000678ceab4f
Location: http://192.168.1.34:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz CINEMA 70s
Device #1: S26-UPnP/AV
Location: http://192.168.1.150:49152/uuid-3a54e941-c644-d275-c112-78e996ba1114/description.xml
Model name: UpMPD
Max. memory for audio buffers: 2012MB
Local Audio Engine: Linux ALSA library 1.2.15.3
Advanced Linux Sound Architecture Driver Version k6.12.67-x86_64-GentooPlayer-ST-RT.
Local devices found : 0
Hi @Matamboy , can you please try to reproduce this with the beta of Audirvāna Studio?
Bonjour Antoine,
Je ne peux pas essayer la bêta de Audirvana Studio 3.0, je passe par la distribution Audirvana Studio de Gentooplayer, il n’ y a que les versions ofiicielles.
J’ai coché l’option Gapless, j’ai l’impression que cela règle en partie ces coupures.
Merci
