Hi, I have transient popping sounds (< 0,5 sek.) when I start playing music with upsampling DSD64 or more. I´am afraid of dammaging me speakers. I tried different parameters without succuss.
Has anybody a hint on what to do?
Greetings, Markus
Audirvana 3.5.42
SoX to DSD64 with filter type B 7th order
Replay Gain: by album
Sync list: 0 folders
Library database path: C:\Users\49175\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1526MB
Local Audio Engine:ASIO 2 driver version 1091
Topping USB Audio Device
Model UID:Topping USB Audio Device
Active Sample Rate: 2822.4kHz
Topping USB Audio Device Manufacturer:
Model UID:Topping USB Audio Device UID:Topping USB Audio Device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: Topping USB Audio Device Manufacturer: Model UID: Topping USB Audio Device UID: Topping USB Audio Device
