tooner3
1
If you select Add Folder in the Settings Local tab, the drive tree is not displayed. Only desktop folders are shown. What could be the problem?
The operating system is Windows 11.
It worked well when I used it as a free subscription to Audirvana Origin.
The free subscription was Origin, but is the studio different?
OneDrive on Windows 11 is the problemā¦
tooner3
3
Thank you for answer.
I didnāt have any problems when using Origin.
Iāll have to delete onedrive first.
tooner3
4
thank you
I set up onedrive and it works fine.
