Hello, I bought the Audirvana software a week ago and have a problem with playing my DSD files. Before Audirvana, I was able to play the DSD files with the Jriver program without any problems. With other Hires files and the integrated Qobuz account, I have No problems with Audirvana. Maybe someone can help me here and maybe also mention various settings as an example to solve my problem. Unfortunately, there is also no operating manual in German that could help me. Thank you in advance.
Hello @Soren_Schmidt,
Can you send me a copy of the “Debug Info” while you have your issue? You can get it in Audirvana Settings>General>Debug Info
I not found the Audirvana folder
You can’t find the debug info button in Audirvana settings?
I found the information, but how do I copy it? I have no sound with dsd even through headphones, just hissing
I reset Windows and reinstalled Audirvana, it works now, but is now only played with PCM 44.1 kHz. Is there a way to increase the playback frequency, e.g. 192 kHz?
Which DAC do you have? Try to find tracks in higher res. Or you can always upsample.
There are no problems with Hires, only with DSD files it shows 44.1 khz. How can I upsamplen there? I have a Marantz SA 10 as DAC, a mutec usb is connected in between
That’s impossible. Can you dump the debug info here. Are you on a Mac or PC?
I’ve never had any problems with Jriver or Roon
PC win 10, I don’t get the debug info copied, otherwise I would have already posted it. How do I get it upsampled?
Once you get the debug info, it’s automatically copied to the clipboard. You just need to paste it here.
Start by installing the USB driver:
https://www.marantz.com/-/media/files/document-master/marantzeu_product_documents/master/marantz_xm_windows_driverv300_for_windows10.zip
where exactly do I find the clipboard and how do I copy it then.Sorry have no idea of
Audirvana 3.5.44
SW volume control: ON
Sync list: 3 folders
Manual: (OFFLINE) C:\Users\sören\Desktop\Various Artists-SACD\Various Artists - Time-Life Legends Get It On
AUTO: C:\Users\sören\Music
AUTO: E:\MUSIK
Library database path: C:\Users\sören\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 10448MB
Local Audio Engine:WASAPI
Lautsprecher (3- MC-3+ Smart Clock USB 2.0)
Model UID:Lautsprecher (3- MC-3+ Smart Clock USB 2.0)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{c38641e9-1fe3-4603-bb53-062a9fb588db}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Sample rate switching latency: 5s
Audials Sound Capturing (Audials Sound Capturing) Manufacturer:
Model UID:Audials Sound Capturing (Audials Sound Capturing) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{3564bc4d-ff40-4c0a-aedc-aac7fca15f33}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
1 available sample rates up to 44100Hz
Simple stereo device: No
Device #0: Audials Sound Capturing (Audials Sound Capturing) Manufacturer: Model UID: Audials Sound Capturing (Audials Sound Capturing) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3564bc4d-ff40-4c0a-aedc-aac7fca15f33}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Lautsprecher / Kopfhörer (Realtek Audio) Manufacturer: Model UID: Lautsprecher / Kopfhörer (Realtek Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3d0bee2e-ad76-42fa-86fb-65a38e4e933d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0DMR-BST835 UID: uuid:4D454930-0300-1000-8000-8CC121C271A4 Location: http://192.168.178.24:60607/8CC121C271A4/Server1/ddd
ok im found,sorry,can help me?
Are you connected to the Mutec device? What happens at the moment is it detects Mutec as only offering 44.1KHz sampling frequency and since you selected to upsample to the max device supported frequency, Audirvana resamples everything to 44.1KHz.
You can install the USB driver for Mutec:
https://www.mutec-net.com/downloads/manuals/MUTEC_USB2.0_Audio_Driver_V4.82.0_03-2020.zip
Select ASIO and disable upsampling. See how it goes. That won’t allow you to play DSD files though, unless Audirvana converts the files to PCM on the fly.
The better approach would be to connect the Marantz directly via USB and install the Marantz drivers. That would allow you to play DSD files natively up to DSD256 (max supported by your device). That would be the better approach.
Thanks for the quick answer, I connected the PC directly to a USB via Marantz and it works. DSD is recognized. Try the Mutec driver, maybe the more recent one
But with Jriver and Roon it’s also sampled by the Mutek at 192khz, so it’s probably due to Audirvana, right?
Audirvana detects it without the driver as only 44.1KHz capable. That’s why if you select max. upsampling frequency, it resamples to that frequency. In Windows without a driver you can play up to 24/96Khz.
If you install the driver, you should be able to play through Mutec up to the max. sampling frequency supported (192KHz).
