J’ai chargé 3.5.50 de 2 facons differentes sur mon Imac / High sierra
sur la 1ere page de Audirvana Community
a partir de la page anciennes licences de My account
dans les 2 cas lorsque je rentre la licence (apres verification sur my account) le message suivant apparait
“il n’y a pas de licence valide pour continuer l’initialisation”
on me propose soit de quitter, soit d’acheter…
Bonjour,
J’ai le même problème : une impossibilité à me connecter sur Quobuz via un Macbook avec El Capitan et Audirvana 3.5.50.
Merci de nous donner une solution à ce problème.
Cordialement,
Bruno
Same issue I reported from day 1 and based on Antoine answer and the fact that my mac can not handle any OS past El Capitan, I decided to move on and my mac will be collecting dust. Too bad but it is time to move to a streamer with built in it’s own interface app like Bluesound, Wiim, Innuos etc. Now I realized why many people prefer streamers over computers.
Hi cOm3,
this is proving quite a challenge for me. I think I’m good until your point 3 when I get lost:
Since I don’t know what was meant by ‘first character’ and ‘tab to autocomplete’ I continued with the sudo command. It went through and then the password was prompted for. No success. I got this report.
I don’t know how to interpret that. I’ll have another go tomorrow which will probably fall through because I’m obviously out of my depth here. I’m resisting upgrading to H Sierra because as you rightly pointed out, El Cap is the latest OSX that allows for integer mode.
Anyway, thanks for trying to help.
best,
Boris
I think it’s a syntax issue in your script (maybe a misplaced carriage return or something like that). I will send you tomorrow my script file version.
Thank you very much for sharing your findings on this.
If I understand correctly, the main requirement for doing this procedure is having a Mac that can run the High Sierra or more recent version of MacOS, right?
Those experiencing login issues need to install an updated Root Certificate. Please send me a private message on the forum to receive the link and install the certificate.
Les personnes qui rencontrent des problèmes de connexion doivent installer un certificat racine mis à jour. Veuillez m’envoyer un message privé sur le forum pour recevoir le lien et installer le certificat.
Direct mode is also possible with High Sierra. There is a ‘hack’ for this that you must perform according to a step-by-step plan. Choice between certificates or core audio hacking.
Funnily enough, I have 140 certificates and none of them is expired! The first one in line to expire is good till 18th December this year. So does that mean that with me the reason I can’t log in to Q is not expired certificates but something else?
The main requirement is to update OS root certificates. But this action require to be secured. Normally, these comme with OS updates (OS updates are themselves secured). Since there is no OS update for El Capitan including updated certificates, we have to find another mean to get updated certificates. One secure way is to have a physical access to a newer Mac. Sending root certificates through web or mail is generally not safe.
Good point.
Unfortunately, I didn’t check the expiration date on my certificate on El Capitan before I updated them. So I couldn’t check on my side.
What I know : the Qobuz certificate for the website is valide until November, 4 2024 :
The former one probably expired November 4 2023… And the API probably use the same certificate…
The root certificate used to sign this new Qobuz certificate is USERTrust RSA Certification Authority.
On Ventura this root certificat exists, maybe not on El Capitan ?
