R8brain cuts off song before it ends. Please advise.
Audirvana Origin 2.1.0 (20100)
macOS 13.0.1 with 16GB physical RAM
Connected account of : Aldo Alvarez
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Effect - Voxengo MSED ()
AU plugin #1: Effect - Voxengo Shinechilla ()
AU plugin #2: None
AU plugin #3: None
r8brain with Power Of Two upsampling
Replay Gain: by track
Sync list: 2 folders
AUTO: /Volumes/Fabulosity 2022/HD
AUTO: /Volumes/Fabulosity 2022/Musicmoved/Music
Library database path: /Users/ADAlvarez/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50660
Max. memory for audio buffers: 256MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
TOPPING D70S MQA
Model UID:D70s MQA:152A:8750
UID:AppleUSBAudioEngine:Topping:D70s MQA:2200000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
Selected device:D70s MQA
Manufacturer: Topping
Model name: Topping D70s MQA
Model UID: D70s MQA:152A:8750
UID: AppleUSBAudioEngine:Topping:D70s MQA:2200000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x41
Audio buffer frame size : 231 to 4096 frames
MQA Decoder device
Stream ID 0x42 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 7
Device #0: ID 0x45 DELL U2520DR
Manufacturer: DEL
Model UID: 10AC58A1-0000-0000-151E-0104B5371F78
Model name: DELL U2520DR
Device #1: ID 0x33 Yeti Stereo Microphone
Manufacturer: Generic
Model UID: Yeti Stereo Microphone:046D:0AB7
UID: AppleUSBAudioEngine:Generic:Blue Microphones:LT_2112230057289D030891_111000:2
USB Vendor ID: 0x046d
USB Product ID: 0x0ab7
Model name: Generic Yeti Stereo Microphone
Device #2: ID 0x41 D70s MQA
Device #3: ID 0x7e External Headphones
Model UID: Codec Output
UID: BuiltInHeadphoneOutputDevice
Model name: Apple Inc. External Headphones
Device #4: ID 0x78 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #5: ID 0x54 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Device #6: ID 0x5e ZoomAudioDevice
Manufacturer: zoom.us
Model UID: zoom.us.zoomaudiodevice
UID: zoom.us.zoomaudiodevice.001
Model name: zoom.us ZoomAudioDevice
