- I got an experimental âhigh(er)â quality link of the Dutch radio NPO klassiek, but it seems I cannot add it to favourites. It shows the heart before the link, but I cannot select it. Bug or feature!?
- I can upsample radio station to the max of my device (T+A Dac200). Normally I set the upsampling to dsd512 (via Ifi streamer) for my local music so I have to switch to another sampling rate the moment I choose Radio. Is the upsampling to dsd in Radio not possible? Bug or feature?
Hi @DonaldM,
Regarding the radio you play with a link, you can add it to a playlist to store it, but you canât add it to your favorites yet.
Upsampling should works whatever if you play a Radio or not. You do not have the option with your T+A selected on AudirvÄna?
Only pcm upsamplings works to even 24-768. But dsd no sound from dsd64 to dsd512. Ifi is the streamer for dsd512 as intermediate. This works with local music upsampling to dsd512 without problem.
Donald
As far as I know Audirvana only upsamples from PCM sources and does not upsample from DSD sources. So this is not a specific radio issue, but simply a limitation for all sources (local files, streaming services etc.). In other words PCM will upsample fine to DSD512, but DSD64/128/256 will not be upsampled at all.
Please paste your Debug information here so we can see your configurations⌠It is found here: Settingsâ> My Accountâ> Helpâ> Debug info
Yes I know. I probably was not clear enough: I ment upsampling from pcm to dsd. With dop it worked to dsd256.
I have exactly the same behavior with radio stations.
In my case I have Audirvana running on Linux currently (I can try Windows and Mac if desired), my streamer is another Linux box on which Iâve installed mpd and upmpdcli, and my DAC is iFi with maximum PCM capability of 768kHz and maximum DSD rate of DSD512.
Audirvana upsamples local sources and Qobuz to DSD512 with no problem, but radio stations wonât play at any DSD rate. Audirvana upsamples radio stations all the way to 768kHz PCM, but not to DSD.
Yes, I use the Neo Stream with the latest software update which makes a digital-to-digital pass through connection possible. As stated before DOP upsampling to dsd256 does work with Radio.
Hi @Antoine ,
No, I am using as a streamer the Fitlet3 minicomputer with optional optical Ethernet input, on which I have installed a minimal Arch Linux without GUI, mpd and upmpdcli.
The streamer is then attached by USB to the iFi NEO iDSD DAC. However, I experienced the same thing before I had this DAC and this streamer. The first few builds of Studio (for Mac and Windows) did not have the issue, but all builds since then have.
Radio upsampling to DSD works with a direct USB connection, but not over UPnP.
The official release was a few days after I posted.
I reported to the development team of Ifi that after a few hours the Neo Stream freezes and a restart is necessary. They will look into it.
@Antoine
Any news on this?
Thanks,
Donald
Still no news?
When you try to play the radio with DSD upscaling, do you get such an error in the GUI of the iFI Neo Stream?
Also, do your DSD settings look like this in the iFI Neo Stream?
Hi,
There is no problem with the Ifi as far as I can tell. Everything works wonderfully now with the latest update from them. I beta tested their solution.
AudirvÄna seems not be able to upsample in DSD. In pcm it works ok, even up to the maximum of my T+A Dac200. Also others (@Jud) in the forum noticed the same behaviour.
@Antoine Are you able to upsample to dsd512 with radio?
Btw: upsampling with local music to dsd512 is no problem, which Ifi can cope with.
My playback settings are different as I do not use the Ifi Dac part:
So you are using a more recent version than the 2.6.13 version?
No. 2.16.13 is the latest version. I tested this version before it came out. Pass through of digital data was originally not implemented with the ifi streamer.
My question to @Antoine is: are you able to upsample in Radio to dsd (any rate) over UPnP!? It seems not be related to ifi, see also the response of @jud above.
I couldnât, it seems the device started playing, but no audio is heard. We need to take a look at this.
