Yesterday I had the ability to use realtime eq in the beta android remote app, today the option is gone.
Exact!
Pour retouver l egaliseur,il faut retourner Ć traitement audio,egaliseur en temps reel ,puis configurer ! Le traitement du signal apparait et disparait aleatoirement lorsque je connecte une souris bluetooth Ć mon telephone,le bouton doit etre cache sur l ecran,en tout cas il n est plus sur la pochette de l album! L appli demande une mise a jour du coreplayer linux fe 2.1 vers 2.6 mais comment faire,mon streamer est un 3Dlab?merci pour votre super boulot!
Vous devriez pouvoir faire la mise Ć jour depuis lāapplication AudirvÄna Remote, si ce nāest pas le cas, vous devez contacter 3D Lab.
Still no realtime eq on android remote (beta). It was there, then 3 weeks ago it disappeared. Are there plans to bring it back?
Itās still there. Have you activated real-time in the processing section of the audio settings?
Yes. Realtime eq is running on the desktop. The only options available on the app are show artists and show album.
Can you send us a copy of the "Debug Infoā when you have this issue? You can get it in Audirvana Settings>My account.
Audirvana Studio 2.11.5 (21105)
Running on iMac (27-inch, Mid 2010)
macOS 10.13.6 x86_64 with 12GB physical RAM
Connected account of : Tom Carvalho
LOADING/DECODING:
Max audio buffer size: 4130MB
Internal EQ: ON in realtime mode
Effect Plugins: NOT ACTIVE
SoX custom frequencies
Bandwidth at 0dB = 99.5%
Phase = 66%
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/Audio/Audio
AUTO: /Volumes/Audio/Hi-Res Audio
Sync folders at startup: NO
Sort and display order: en_US
Library database path: /Users/TC/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 3604
Listening on 127.0.0.1 on port 55777
Font size: regular
Show album covers in tracks list: no
Streaming
My Music
Radios
Podcasts
Use Apple Remote: no
Number of paired remotes: 7
Screen saver disabled: no
Max. memory for audio buffers: 4130MB
Local Audio Engine: CoreAudio
Exclusive access: OFF
Integer mode: ON
Actual I/O buffer frame size: 4096
AudioQuest AudioQuest DragonFly Black v1.5
Model UID:AudioQuest DragonFly Black v1.5:21B4:0083
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Black v1.5:AQDFBL0100114202:1
Selected device:AudioQuest DragonFly Black v1.5
Manufacturer: AudioQuest
Model name: AudioQuest DragonFly Black v1.5
Model UID: AudioQuest DragonFly Black v1.5:21B4:0083
UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Black v1.5:AQDFBL0100114202:1
USB Vendor ID: 0x21b4
USB Product ID: 0x0083
ID 0x28
Max volume alert: Disabled
Not automatically detected, user set to MQA Renderer
Stream ID 0x29 2 channels starting at 1
8 virtual formats:
8 physical formats
Local devices found : 3
Device #0: ID 0x38 Built-in Output
Model UID: AppleHDA:24
Device #1: ID 0x28 AudioQuest DragonFly Black v1.5
Device #2: ID 0x2c USB Audio DAC
Manufacturer: Burr-Brown from TI
Model UID: USB Audio DAC :08BB:2704
UID: AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :fa130000:1
USB Vendor ID: 0x08bb
USB Product ID: 0x2704
Model name: Burr-Brown from TI USB Audio DAC
Wi-Fi
Can you please try with the beta version of AudirvÄna Studio?
It was a available a couple of weeks ago on 2.11.5, right? Iām not crazy. I canāt load the beta on Mac os 10.13.6, can I?
Sorry, indeed, you canāt load the beta on your OS version. Can you please send me a screenshot of the Remote audio settings when you have your issue?
Hmm, I could reproduce this. I need to ask our developper over this.
Thank you Sir.
