Is it me or something disappeared from the new version 1.7?
I was used to have the total number of albums, tracks and listening time when selecting “albums” in the local view. Are they gone?
Bonjour,
Impossible de faire la mise à jour vers un 1.7…
Messages erreur
Audirvana 3.5 …
Idem impossible de faire la mise à jour…
Je ne renouvellerais pas l abonnement… Trop de bugs !!!
And how is the UI with the new big fonts?
These are the new?
They seem bigger indeed. Can you post a screenshot of a bio please?
Good eyes there, No totals on album main page but if you select an album it there for individual albums
Not a big deal but this should let them know about it.
You are on windows?
Seem to be a procedure to follow
Yes windows 10…
Henri try here
It would be even easier if Antoinne implemented a new line between paragraphs, otherwise you just get a big monolithic slab of text in a bigger font.
As SandsofArakkis says the fonts are quite a bit larger - which works for things like biographies but is less successful elsewhere as lots of things get truncated.
Could use a bit more adjustment, the bios needed it bad but the rest was ok for me
Going back to it this morning, I was a bit harsh - the bigger fonts are an improvement pretty well everywhere.
Hopefully implementing paragraph spacing in blogs and reviews should be simple.
Since the new version 1.7 - looks an works much better than before. Sometimes seems to crash - restart - and then every!!! time I have to tip my account and password on login screen! Not really true, or?
Thanks, seems to work.
I am starting to like Studio!
Don’t know exactly which improvements people see on the new version and I sincerely hope there are some, but on my side, apart from the lack of information about the total number of albums, I still got crashes with the exception EXC_GUARD.
That means the application is manipulating something (File descriptor) he does not own:
Process: Audirvana Studio [17946]
Path: /Applications/Audirvana Studio.app/Contents/MacOS/Audirvana Studio
Identifier: Audirvana Studio
Version: 1.7.0 (10700)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Audirvana Studio [17946]
User ID: 501
Date/Time: 2021-09-25 04:47:34.055 +0200
OS Version: Mac OS X 10.15.7 (19H1417)
Report Version: 12
Bridge OS Version: 5.5 (18P4759a)
Anonymous UUID: 11010C5D-11BE-F6C5-C6FD-ACEF6477FDCF
Time Awake Since Boot: 290000 seconds
System Integrity Protection: enabled
Crashed Thread: 64
Exception Type: EXC_GUARD
Exception Codes: 0x6000000000000012, 0x0000000000000002
Exception Note: EXC_CORPSE_NOTIFY
And, on top on that, if you disconnect from your account, you have to be sure you remember your password as it apparently cannot be recorded on your machine.
I was forced to start the procedure to renew my password. Code owner is protected, user is pissed off.
