For quite some weeks, Remote does not load the library (neither on iPad nor iPhone). Remote displays âLoadingâ endlessly however does not load.
Remote connects properly, the track playing is displayed correctly. I use the latest versions of both Remote and Audirvana for Mac. The library contains 4000 albums and over 60000 tracks however if i filter (to display just a part of that) that does not make any difference.
Have you tried to restart your WiFi router? it may have a problem transmitting the connection used by Audirvana Remote (Like the Apple Remote app that controls iTunes, which can be blocked for the same reasons)
Hello Damien,
I restarted the router to no avail. I disconnected the hard disk, restarted Macmini. Moved sqlite db. Connected harddisk again. Had Audirvana build up a new library. Restarted Remote on iPad and iPhone.
Again just the âLoadingâŠâ message, despite the fact the Remote indicates the track playing and Remote can control (start/pause) the track playing.
Looking forward to any other suggestions
[Edit: I just tried Remote on iPhone with my iMac, same problem: just the âLoadingâŠâ message]
Yes, it is connected to a Mac mini using a USB 3.0.
The issue with Remote however appears in both configurations (macMini and iMac).
The only difference being that the external RAID 0 harddisk is connected to iMac through a hub.
Still, the app shows the track currently playing, however when I chose Album in the Remote app it shows endlessly âLoadingâ and does not show the Albums.
However I found something very odd : despite the Albums not being shown, all Tracks are shown in the App!
As mentioned, until some weeks, say 2-3 months ago it worked perfect.
Do you in the meantime have any suggestions that would solve this? Pls let me know if I can provide any additional information.
I was too premature. It works for just one of the Macâs both connected to the same network via ethernet and via the same switch.
With the iMac the Albums show, with the Mac mini it endlessly displays âLoadingâ etc.
Does anybody have any suggestions how to resolve this?
I really like Audirvana and would very much like to stick to Audirvana, however this make Audirvana unworkable for me
Can you check your firewall settings: In System Preferences > Security and Privacy > Firewall > Firewall Options > Automatically allow signed software to receive incoming connections check that this setting is selected and âBlock all incoming connectionsâ is not selected.
Hello Damien,
Just checked. The firewall of the Mac mini was off. I just set it on and Audirvana was allowed to make incoming connections. Both settings resulted in the â LoadingâŠâ message.
Would you have any other suggestions?
Hello Damien,
What I - as a layman - find hard to understand is that with Remote from the Mac mini
all âTracksâ are displayed, however âAlbumsâ are not and
in the standard Playlist âRecently Addedâ all âTracksâ, are displayed however âAlbumsâ not.
How has this anything to do with the connection, router etc, if half of the info is displayed and the other half not?
Can you check your database using the three commands in the Maintenance section of the preferences page? What is the speed of your wi-fi between your phone and your wi-fi router?
I just performed - as I do one a weekly basis - the 3 maintenance actions.
In the specific location of the audio setup the wifi speed - depending on the app used - is either
down 186Mbps/up 146 or
down 207/up227 Mbps,
which should be sufficient, I guess
However still the Albums do not appear.
To add to my previous post: if I search for Albums of a specific Composer, all of the Albums of that Composer (in my test 114 albums) appear instantly.
At the moment the database comprises approx. 3.600 albums and 62.000 tracks. (Funny enough, all âTracksâ load without hesitation)
Do you have any further suggestions. I would be happy to provide additional information
