Review: High-end Yamaha receiver versus a dedicated UltraRendu with Audirvana upsampling
Introduction
In my recent review of Audirvana Studio, I documented my journey optimizing upsampling settings to achieve what I described as āmagicalā sound quality through my UltraRendu ā IsoRegen ā Benchmark DAC3 chain. Shortly after publishing, an interesting comment appeared from a forum member suggesting I might achieve even better results using my Yamaha RX-A8A receiverās ES9026PRO DACs:
āWhy donāt you use the RX-A8A for high-resolution playback? It uses the ES9026PRO Hyperstream II chipset (2x) supporting up to 32/384kHz and DSD256⦠you say it sounds awesome [for surround SACDs]⦠You would gain the room correction DSP in concert with up-samplingā¦You can connect your mono-blocks to the pre-amp outputsā¦ā
The suggestion was intriguing. My Yamaha RX-A8A is indeed a high-quality receiver with impressive specifications, including dual ES9026PRO DAC chips capable of DSD256 and 32-bit/384kHz PCM processing ā capabilities that exceed my Benchmark DAC3ās DSD64 limit. Could my carefully optimized multi-box solution be outperformed by a modern integrated receiver?
I love a challenge related to my favorite hobby (listening to music), especially a challenge that might save me and others money or simplify our systems. So I embarked on a methodical listening comparison between these two very different digital playback chains, using identical content and source components. The results were illuminating, sometimes surprising, and provide valuable insights for anyone considering different digital playback configurations with Audirvana.
Test Setup
Common Elements:
- Mac mini (late 2012) with Audirvana Studio
- Identical upsampling settings for each comparison
- Same reference tracks across all tests
- Similar power cables (high end power cord on the receiver, similar cables and linear power supplies on the IsoRegen and UltraRendu)
- Same amplifiers
- Same speakers
Setup A (Reference):
- Audirvana ā UltraRendu (via UPnP/DLNA over EtherRegen switch) ā IsoRegen (USB reclocker) ā Benchmark DAC3 ā Yamaha RX-A8A balanced input
- SoX upsampler with optimized settings from previous review
- DSD64 conversion with Type A (4th order) modulator
- Digital components powered by linear power supplies (LPS)
Setup B (Alternative):
- Audirvana ā Yamaha RX-A8A (via UPnP/DLNA over EtherRegen switch)
- Various upsampling configurations tested (detailed below)
- PCM 384kHz/32-bit and DSD64/128/256 tested
- Both SoX and r8brain upsamplers evaluated
Note that I connected the Benchmark DAC3 of Setup A to the Yamaha receiverās input, instead of to my mono block amps. This way, either setup users the Yamahaās pre-amp. So I really tested DAC performance and not the pre-amp or amps.
Key Findings
Sound Character Differences
Benchmark DAC3 (Reference Chain Setup A):
- Deeper, more three-dimensional soundstage
- More sustained and impactful bass reproduction
- āBlackerā background with better contrast between instruments
- More natural decay of instruments and reverb tails
- More emotionally engaging overall presentation
- Superior reproduction of hall ambience and spatial cues
Yamaha RX-A8A (Direct UPnP/DLNA Setup B):
- Clean, detailed sound with precise imaging
- Flatter soundstage compared to reference system
- Less sustained bass with quicker decay on low frequencies
- Excellent clarity but sometimes with a more analytical character
- Slightly drier presentation with less natural reverb
- Very good but less emotionally engaging reproduction
Format Preferences
One of the most surprising findings was how differently each DAC responded to various digital formats:
Benchmark DAC3:
- Performed best with DSD64 conversion
- Exhibited that āmagicalā quality with optimized SoX settings
- Higher DSD filter orders (5th-8th) reduced naturalness
Yamaha RX-A8A:
- Performed best with PCM 384kHz/32-bit
- Noticeably preferred PCM over DSD (at any bit rate)
- Produced audible relay click when switching between PCM and DSD (indicating different signal paths)
- r8brain upsampler provided better bass than SoX for this DAC, but overall I still preferred SoX
- When using DSD, the Filter Type A with 5th Order sounded better than my reference systemās 4th Order. But 6th-8th introduced a very slight āveilā over the music.
Detailed Listening Observations
I used seven reference tracks for consistent evaluation. Here Iāll highlight the most revealing findings from three representative tracks:
āSleepers Beat Themeā - Ben-Lukas Boysen
This minimalist track with ultra-deep bass and piano revealed stark differences:
Benchmark/DSD64:
- Deep bass notes sustained naturally with long decay
- Physical sensation of bass pressure during sustained notes
- Piano attacks with both precision and natural harmonic character
- Harp positioned distinctly far behind the piano in the soundstage with natural sparkle
- Exceptional contrast between notes and silent background
Yamaha/PCM384 (best configuration):
- Deep bass present but with shorter sustain
- Less physical impact from bass notes
- Good piano definition but slightly less dynamic
- Harp positioned more forward in the soundstage
- Good but less dimensional presentation overall
Yamaha/DSD256:
- Bass less sustained than PCM384 version
- Slightly ālighterā overall tonal balance
- Less natural piano timbre
- Flatter soundstage presentation
āPowaqqatsi Anthem Pt. 3ā - Philip Glass
This complex orchestral piece with subtle spatial cues was particularly revealing:
Benchmark/DSD64:
- Snare drum positioned with natural reverb extending deep into the wider soundstage
- Left-to-right panning synthesizer moves with precise tracking
- Pan flutes with natural āvelvetyā texture and air
- Timpani remains powerful and defined during crescendos
- Individual instruments maintain separation during complex passages
- Snare drum positioned a bit more forward with less reverb extension
- Panning synthesizer movement less distinct
- Pan flutes clean but with less spatial information
- Timpani present but less impactful during crescendos
- Some minor smearing during the most complex passages
Yamaha/DSD128 (with forum-suggested r8brain settings):
- Slightly veiled presentation overall
- Less distinct panning synthesizer
- Slight crackling artifacts in pan flutes before crescendo
- Timpani lacking full power during climax
- Generally less transparent than PCM384 version
āEvacuationā from I Am Legend - James Newton Howard
This emotional orchestral/choral piece tests separation and layering capabilities:
Benchmark/DSD64:
- Opening cellos with natural body and warmth
- Strings and choir distinctly layered in separate spatial planes
- Deep bass synthetic effects with power and control
- āAngelicā female choir with presence, natural roundness and air
- Timpani positioned naturally at the rear of the soundstage with power during crescendos
- Good cello definition but less warmth
- Less distinct separation between choir and orchestra
- Deep bass present but less physically impactful
- Female voices slightly drier and more forward
- Some smearing in central orchestral passages during climax
Upsampling Algorithm Comparison
An unexpected finding was how differently each DAC responded to upsampling algorithms:
SoX Upsampler:
- Provided clearly best results with Benchmark DAC3
- Allowed fine-tuning of multiple parameters
- Optimized settings discovered in previous review worked perfectly with Benchmark
r8brain Upsampler:
- Improved bass with Yamaha RX-A8A, but I still preferred my SoX settings overall
- Added more warmth and bass presence to Yamahaās presentation
- Limited adjustment parameters compared to SoX
- Default settings provided reasonably good results with Yamaha at 384kHz (multiple of 2 upsampling)
Technical Analysis
What explains these consistent differences between two high-quality DAC implementations? Several factors likely contribute:
1. Power Supply Implementation: The Benchmark DAC3 benefits from a dedicated, optimized power supply, while the Yamahaās DAC section shares power resources with its many other functions. Clean power has proven crucial in my previous optimizations.
2. Jitter Reduction Chain: My reference system includes multiple stages of clock regeneration (UltraRendu ā IsoRegen), significantly reducing timing errors that affect soundstage reproduction and bass definition.
3. Analog Output Stage Design: The Benchmarkās analog output stage is designed specifically for two-channel audio, while the Yamaha must accommodate multichannel processing and other features.
4. Signal Path Optimization: The Yamaha appears to have different internal signal paths for PCM and DSD (evidenced by the relay click when switching formats), with the PCM path likely more direct and optimized.
5. Implementation Priorities: The Benchmark focuses entirely on audio quality, while the Yamaha balances this with versatility, surround and DSP features, and other design considerations.
Conclusion
Does the Yamaha RX-A8A with its ES9026PRO DACs outperform my optimized UltraRendu ā Benchmark DAC3 chain? In short: no. Despite impressive specifications and capabilities, the Yamahaās DAC implementation cannot match the emotional connection, soundstage depth, and natural presentation of my reference system.
However, this doesnāt diminish the Yamahaās accomplishments. As a multi-purpose receiver, its performance is impressive, especially with PCM 384kHz and Audirvana upsampling. For many listeners, particularly those without extensively optimized systems, the Yamaha could provide outstanding results.
Key takeaways for Audirvana users:
- Implementation matters more than specifications - The Benchmark DAC3 with āonlyā DSD64 capability consistently outperformed the Yamahaās DSD256 and PCM384 capabilities because of superior implementation.
- Different DACs prefer different formats - The Yamaha performed best with high-resolution PCM, while the Benchmark excelled with DSD64 conversion.
- Upsampling algorithm selection matters - SoX worked best with the Benchmark and was also my favorite with the Yamaha, but r8brain better complemented the Yamahaās neutral bass character (my SoX settings sounded leaner with the Yamahaās DAC).
- Power supply quality remains crucial - The benefits of my linear power supplies were evident throughout testing, reinforcing their importance in digital audio chains.
- System synergy trumps individual components - The cohesive design of my reference system created a performance level greater than the sum of its parts.
This comparison reinforces what many audiophiles discover: specifications alone donāt tell the whole story. My multi-box approach with the Benchmark might seem āoverly complicatedā compared to the Yamahaās newer technology, but careful implementation, optimization, and system synergy created a musical experience that the integrated solution couldnāt match. This obviously also comes at a significantly increased cost. But I think Audirvana users aim for maximum musical enjoyment and the UltraRendu isnāt the most expensive solution, even with a good linear power supply.
For those with Yamaha receivers wanting to maximize performance with Audirvana, I recommend:
- Use PCM 384kHz/32-bit rather than DSD conversion
- Try both the SoX and r8brain upsamplers
- Consider a clean power supply for your streaming device
- Definitely replace the receiverās bundled power cord. Even an inexpensive āaudiophileā cable from Amazon or Temu around ā¬60-ā¬90 can do a lot (but be sure to try them out because some of them, especially silver infused ones, resulted in worse sound for me ā I found neutral shielded copper best as an inexpensive step up. Although I ended up in higher end price ranges from Canadian and U.S. suppliers for my amps and UltraRenduās LPS. Make sure that your power cables are at least 1,5m/5ft in length, 6ft is ideal).
For now, my optimized Audirvana ā UltraRendu ā IsoRegen ā Benchmark DAC3 chain remains my personal reference for āmagicalā musical enjoyment.
System Details
Equipment Used:
- Ethernet Switch: Uptone Audio Etherregen, powered by Uptone JS-2 Linear Power Supply at 12VDC
- Player: Mac mini (late 2012) with Uptone Audio DC-Conversion / Linear Fan Controller Kit, powered by Audiophonics LPSU200 LPS
- Network Streamer: Sonore UltraRendu powered by Uptone JS-2 LPS
- USB Reclocker: Uptone IsoRegen powered by sBooster LPS (set to 6.5V) [corrected ā in the initial version of my review I incorrectly wrote that the IsoRegen is powered by the JS-2 LPS] and connected to the DAC using an Uptone USPCB adapter
- DAC: Benchmark DAC3
- Receiver/Alternative DAC: Yamaha RX-A8A
- Speakers: Bowers & Wilkins 802 D2
Optimized Audirvana Settings (Reference):
- SoX Filter Bandwidth (% Nyquist): 94.5
- SoX Filter Max. Length: 23296
- SoX Filter Anti-Aliasing (%): 96
- SoX Filter Phase (Min. Phase to Linear): 66
- DSD Sigma-Delta Modulator Filter Type: A (4th order)
- Safe volume reduction before DSD upsampling: -4dB
Best Yamaha Settings:
- Format: PCM 384kHz/32-bit
- Upsampler: SoX or r8brain (both need tweaked settings, r8brain seems to result in slightly better bass response)
- Yamaha Pure Direct mode enabled
ā-
Note on AI assistance
I used Claude.ai to help organize my findings from this extensive listening comparison. During approximately eight hours of testing, I typed about 7,000 words of raw observations and questions into Claude, including detailed listening notes for all seven reference tracks. Claude already had knowledge of my system setup and previous optimization results (from my earlier Audirvana SoX tweaking review), which provided helpful context. Claude helped transform the information into this more structured 2,000-word review, where it identified three representative tracks where the differences were most revealing and confirmed over multiple listens. The analysis entirely reflects my actual listening experience and conclusions, with Claude helping with organization and technical explanations for what I was hearing. I made final edits and refinements before posting.
