I recently downloaded a trial for Audirvana to test against Roon.
While tinkering in Audio settings, I noticed, SysOptimizer: Disabled
That made me curious enough to Google and I find forum threads with Witch doctors performing some sort of voodoo with Terminal commands and copying and pasting files.
And frustrated customers not understanding any of it.
When I installed Audirvana, I never got this magical window people keep screen grabbing of the SysOptimizer setup. With absolutely now way of knowing how they got there.
There appears to be no rhyme or reason to why some are affected and others are not.
Can anyone provide any simple to follow instructions or an answer as to why this occurs. Anything that can help me move forward so I can hear this improved audio everyone is touting?
Thank you for the response. I have tried all the Voodoo. And uninstalled Audirvana and reinstalled. I am running v1.3. Nothing. Audio settings still reporting SysOptimizer: Disabled. And during either install I was never given any option to optimize anything.
I can see it exactly where you are pointing. But I have a settings wheel there that does nothing. I have been clicking on it for hours with 0 of anything happening.
You can try deleting your preferences of Audirvana and try again…
or maybe just copy your prefs in another place on your mac,
drag them out of the folder with option key press to make a copy of it
then delete your prefs, if not working just put back your copy where it was…
Close Audirvana.
trash com.audirvana.Audirvana-Studio.plist
Restart Mac. Restart Audirvana and play a song and see, should ask to install SysOpt…
did you put the Audirvana Application in your Applications folder on your Mac?
when you open a software, you automatically have a preferences file for it… any soft…
Yes. v1.3 went into my Applications folder. The latest version.
Audirvana installed and first run, all I got was the initial splash screen detailing all the new features.
Nothing resembling any preferences. Nothing.
Terms like HOME folder and Library folder are not terms I am familiar with. I am coming from a lifetime on PC and Windows. The path I followed to find the preferences file were.
Macintosh HD > Library > Preferences.
Nothing resembling what you siad I should be finding.
