Hi there,
I completed a bit perfect test with my RME ADI 2 DAC, utilising the RME bit tests on their website. These tests, check playback chain for bit perfect capability, and notify the user of the bit rate and pass/fail on the front of the DAC.
Using Audirvana, the tests pass on 16, and 32bit depths, but failed on 24bit.
As a comparison, I used Jriver and Foobar, to perform the same tests.
Jriver passed on all bit depths. 6, 24, 32bit, no issues.
Foobar passed up to 24bit, but failed on 32bit depth.
I am not using any sampling, or volume control.
All tests used the same Asio driver from RME.
DEBUG:
Audirvana 3.5.38
Per track: OFF
Sync list: 3 folders
Manual: (OFFLINE) E:\FLAC MUSIC
Manual: (OFFLINE) E:\WAV MUSIC
AUTO: C:\Users\Steve\Downloads
Library database path: C:\Users\Steve\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1914MB
Local Audio Engine:ASIO 2 driver version 1
Analog (1+2) (RME ADI-2 DAC)
Model UID:Analog (1+2) (RME ADI-2 DAC)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{131bc92d-151e-4452-b232-fefe3e0d3ee2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
ASIO MADIface USB Manufacturer:
Model UID:ASIO MADIface USB UID:ASIO MADIface USB
13 available sample rates up to 11289600Hz
2822400
5644800
11289600
DSD capability: Raw DSD (MSB)
Device #0: ASIO MADIface USB Manufacturer: Model UID: ASIO MADIface USB UID: ASIO MADIface USB
Device #1: JRiver Media Center 26 Manufacturer: Model UID: JRiver Media Center 26 UID: JRiver Media Center 26
