Short loud noise when changing tracks?
I’m having this issue when I play my playlist in shuffle and doesn’t happen with all tracks. It’s not even reproduceable, next time that track won’t do it and some other will. See here and sorry for the poor sound:
Setting are Kernel streaming, no VST processing, no upsampling, no volume levelling, volume control inactive. Volume on the dac is 100% and…
AV
Any ideas?
Only a WAG but perhaps try “ mute during sample rate change “ maybe add some time in “latency when changing sample rate “
Best luck with it
What’s a WAG?? Wild arse guess? Never seen that one before :grin:
Still having this problem… :cry:
I remember I had the same issue with some other player but then there was an option to force silence between tracks. I see Audirvana has no such options but maybe this is a clue to someone that might know what is going on?
You tested the two settings I had suggested to try out? No good?
How about you post your debug and we can get some more ideas perhaps?
Paging Mr @Agoldnear did i suggest the correct settings, any suggestions?
@OffRode … This is where I’m at now… I posted a link to an iFi Audio Blog post regarding the sample-rate change “pop” in my original topic:
You think of any other settings he can try? No debug yet, he’s on windows as well
@OffRode …Apparently using WASAPI can insert the silence with some players… it is described on line (6) in the blog post I have linked in my topic post… I have no clue if Audirvana implements this under WASAPI… this muting thing is random as I describe in my answer to my own post… The “pop” is not completely muted, but it can be inconsequential… it is not consistent and I don’t know what settings will improve… I’ve tried adding latency and it does not change the behavior with my DAC and macOS…
I tried the mute option with 1 second latency and that didn’t work. I’ve tried with 2 seconds and the same happens.
It also appears to me that this doesn’t happen when there’s a change in sample rate, I’ve been looking at the displayed sample rate on Audirvana and the DAC front plate and the pops happen with no change…
I didn’t want to go for WASAPI as this and ASIO sound very similar to my previous player. It’s the Kernel Streaming that makes all the difference.
I’ll post a debug ASAP
Audirvana Origin 2.2.3 (20203)
Windows 11 (22621) with 24GB physical RAM
Connected account of : Renato Morais
Bandwidth at 0dB = 99.5%
Phase = 66%
Max allowed volume: 90.1051
Sync list: 2 folders
AUTO: D:\Utilizador\Music\Classic V2
AUTO: D:\Utilizador\Music\Music
Library database path: C:\Users\morai\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:11:8910:1d70:7fc0:6f1d:8e07:1bc9 on port 55274
Max. memory for audio buffers: 23442MB
Speakers (DENAFRIPS USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_86EF&REV_0312&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{8771b222-8511-4abd-b7f9-121413cdd1e6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Sample rate switching latency: 2s
Selected device:Speakers (DENAFRIPS USB DAC)
Manufacturer: DENAFRIPS Co. Ltd.
Model name: DENAFRIPS USB Audio V3.12
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_86EF&REV_0312&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{8771b222-8511-4abd-b7f9-121413cdd1e6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x152a
USB Product ID: 0x86ef
Kernel Streaming capable
12 available sample rates up to 1536000Hz
1411200
1536000
Simple stereo device: No
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 1411.2kHz
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 1536kHz
2 ch Integer PCM 16bit little endian 1411.2kHz
2 ch Integer PCM 16bit little endian 1536kHz
Local devices found : 4
Device #0: Speakers (DENAFRIPS USB DAC)
Device #1: Speakers (D10)
Manufacturer: Microsoft
Model UID: USB\VID_152A&PID_8750&REV_0102&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7b544242-5484-4648-9c71-b6e28812f702}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Product ID: 0x8750
Model name: D10
Device #2: LEN D27-20B (NVIDIA High Definition Audio)
Manufacturer: NVIDIA
Model UID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0080&SUBSYS_103C8338&REV_1001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3e7bfc0a-119c-4581-b377-bdb62c00c05e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: LG TV (NVIDIA High Definition Audio)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f7d2722d-037e-44fc-be0f-91bcda5c7d6c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0: [LG] webOS TV UM7000PLA
UID: uuid:7cd8c15c-f862-d14b-42e0-bd52306bb652
Manufacturer: LG Electronics.
Model name: LG TV
Move your audio buffer size down to between 4000 / 6000 mb and then run a new test. You have almost all of your ram tied up, shouldn’t need to be so large.
What happen if put at 100?
Good catch Mr
Thanks guys, will try the buffer resize.
As to 100% volume, it acts just the same. In fact, it was at 100% until yesterday, when I changed it to see what happens.
Kutusov I have this exact same issue with Audirvana Studio. Disabling upsampling and enabling “ mute during sample rate change “ made no difference for me. This noise only happens using Kernel Streaming regardless of setting (extreme, high or standard) and appears to be random occurring on a track then next time not.
Only using WASAPI or ASIO eliminates this noise completely.
Me too.
Well, suggestions didn’t help, it behaves the same.
To be honest, it sounds like an hiccup when changing tracks, like when it skips to the next, it lands on the middle of another track for half a second and then goes to the correct one.
I’m going to try ASIO to see if this happens with my system or not, like @Tuneman suggests.
Yep, doesn’t happen at all with ASIO or WASAPI.
Seems as if Origin and Studio are the same in this respect which makes sense.
I do believe they are working on this and that they are aware of it.
Hi, I am a new Studio user and had the same problem with Kernel streaming from the beginning of trial period. Today I found some old answer somewhere on this forum, but forgot from whom it was (apologies, didn’t copy it), saying to just turn the Audirvana volume control on, don’t have to use it, leave it on 0,0 (as it is).
It works for me, no more noise when the tracks are changing. Been listening for couple of hours without any problems. Hope it helps.
