Hi!
Currently trying out Studio leaning towards to buy the yearly because I really like the handling of it because it fits so nicely with Tidal.
This is my current setting with my SMSL C100 (Specs):
I deactivated auto MQA DAC detection because when activated, Audirvana did the first unfolding job, even the DAC is capable of doing so also. With the above setting, everything is working as expected (C100 does the whole MQA process).
When I play sample DSD files (DSD64 and DSD256 in .dsf format) from my disk, they are passed to the C100 and are played with the max. Sample rate Kernel-Streaming allows. With DoP activated, no matter if 1.0 or 1.1 I get a moving progress bar but no sound.
But the only problem I recognized that Studio does not recognize the DSD capabilities of my C100 DAC seen in the screenshots above. So if I want to upsample e.g. a FLAC from Tidal to DSD256, Audirvana does not let me unfortunately because the DSD option is greyed out, even if my locally stored files play without any problems and the DAC is capable to handle up to DSD512 natively.
I installed latest XMOS Driver 5.58 for the device. Firmware is also up-to-date. How can I fix this? Can I even fix this? Thanks for your answers!
Audirvana Studio 2.6.5 (20605)
Windows 11 (22631) with 16GB physical RAM
Connected account of : XXX
Available network interfaces:
Ethernet ({3757bd34-d9f5-4364-bf75-c37bed718760}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
AUTO: D:\Hi-Res
Library database path: C:\Users\blingbling\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 184
Listening on fd00::7f1d:6c4f:4c9d:1989 on port 9277
TIDAL: Connected as HiFi Plus
Max. memory for audio buffers: 8122MB
SMSL C100 DAC (SMSL USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_85DD&REV_0351&KS
UID:\\?\SWD#MMDEVAPI#{0.0.0.00000000}.{9d93f315-2b10-4db4-8644-e2c696ee009d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Selected device:SMSL C100 DAC (SMSL USB DAC)
Manufacturer: XMOS
Model name: SMSL USB AUDIO
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_85DD&REV_0351&KS
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{9d93f315-2b10-4db4-8644-e2c696ee009d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
Kernel Streaming capable
Simple stereo device: No
Local devices found : 8
Device #0: Lautsprecher (Steam Streaming Speakers)
Manufacturer: Valve Corporation Audio DDK
Model UID: ROOT\SteamStreamingSpeakers
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{d4046ae7-e990-43d3-9799-f760baf2d063}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Device #1: Lautsprecher (Steam Streaming Microphone)
Model UID: ROOT\SteamStreamingMicrophone
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{5b975b97-2bd6-4cb4-bc95-794db50f01ba}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: SMSL C100 DAC (SMSL USB DAC)
Manufacturer: XMOS
Device #3: Audio (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_104386C7&REV_1003
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{ed8ffa2b-09be-4837-9628-c2db364d5035}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: Realtek Digital Output (Realtek(R) Audio)
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{c60d386d-4138-4458-86e8-46a3b0465af4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #5: Acer B246HYL (NVIDIA High Definition Audio)
Manufacturer: NVIDIA
Model UID: HDAUDIO\FUNC_01&VEN_10DE&DEV_009E&SUBSYS_1043883C&REV_1001
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{1a934ceb-8ac1-41a9-967a-bec102a5cf21}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #6: Acer B246HYL (NVIDIA High Definition Audio)
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{444b3a14-1539-4556-9ac6-ddf46bc95701}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #7: Acer B246HYL (NVIDIA High Definition Audio)
UID: \\?\SWD#MMDEVAPI#{0.0.0.00000000}.{45ee371e-a55a-4ada-9a11-14bd33daa777}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0: Fernseher Schlafzimmer
UID: uuid:8eef9137-2135-11eb-8f13-f0e5e4a45452
Location: http://192.168.2.123:38400/MediaServer/rendererdevicedesc.xml
Manufacturer:
Model name: Renderer
