Hi Damien,
I gave problem in installing a second license only new Mac Book pro.
can you please help?
thanks
christian
@christmas72 - I have removed all your computers from the license database.
You can now activate up to two Mac computers you want with your license key.
To install Audirvana on your second Mac, you can proceed as for the first one:
- install trial version
- unlock it by loading your same license key
Hi Damien, I have the same issue. My Mac was used at my previous work and I now need to install Audirvana on my new MacBook. I only need one license. Can you help?
@EricB - I have removed all your computers from the license database.
Hi Damien,
thanks a lot!!!
christian
Hi Damien,
I have the same issue with a Windows installation.
I had Audirvana running on an older PC that recently died.
I bought a new PC and installed the test version first but when this expired now and I tried to enter my license it gave me the “too many licenses” error.
I can uninstall on the old PC as this is no more working.
Regards
Claus (ckdf2@web.de)
@ckdf - I have removed all your computers from the license database. You can now activate up to two PC computers running Windows 10.
To install Audirvana on your PC, you can proceed as follows:
- install trial version : https://audirvana.com/try-windows/
- unlock it by loading your license key
Thanks a lot Damien. All is good now.
Hi Damien, will you remove my licenses from all computers. After reinstalling my mac, I get the message that I have too many licenses. My license is: License key censored by moderators for security reasons
Allan
@allankjaer - I have removed all your computers from the license database.
I have the same issue as well, can you please clear out my computers?
@slackbits - I have removed all your computers from the license database.
@muneH - I have removed all your computers from the license database.
Hi Damien,
I had Audirvana running on an older PC.
Regards
Jean-Yves
Hi Damien,
Du to mac mini solded without removing a license, would you like to remove all my licences from data base ?
How can I upload and old version of Audirvana ?
Thanks in advance
@Antoine - Could you also remove all of my license from the database please? My old machine broke, so I have no way to de-authorize it.
On another note, I think a “de-authorize all computers” button will be very helpful.
You can now activate up to two Mac or PC computers you want with your license key.
To install Audirvana on your second Mac or PC, you can proceed as for the first one:
Merci de votre réactivité !
