Stops at end of first track
Audirvana stops at the end of whichever first track I’m playing when using Qobuz or my own downloaded files .I have to manually advance to the next track and then it performs fine until I start a new recording - then once again whichever first track I choose it stops .
Hello @Noodle,
Sometimes it happens to me too, but not very often.
ID 0x0 Lindemann Manufacturer:Lindemann audiotechnik GmbH
Model UID:Lindemann audiotechnik GmbH Lindemann UID:uuid:94d27917-b468-4222-b0df-2789324f82b3
Volume control: No
DSD capability: Raw DSD (MSB)
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/l16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
:audio/mpeg:DLNA.ORG_PN=MP3
http-get::audio/vorbis:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/x-aiff:
http-get::audio/m4a:
http-get::audio/wav:
http-get::audio/x-dsd:
http-get::audio/mp4:
http-get::audio/x-dsf:
http-get::audio/mpeg:
http-get::audio/aac:
http-get::audio/dsd:
http-get::audio/aiff:
http-get::audio/x-dff:
http-get::audio/wave:
http-get::audio/x-flac:
http-get::audio/l16;rate=44100;channels=2:
http-get::text/xml:
http-get::audio/x_pm_flac:
http-get::audio/flac:
http-get::audio/l16;rate=48000;channels=2:
http-get::application/ogg:
http-get::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-dsd:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/mpeg:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/dsd:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/3gpp:
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::text/xml:
rtsp-rtp-udp::audio/x_pm_flac:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:
rtsp-rtp-udp::audio/ogg:
DLNA 1.5: Yes
Gapless playback: Yes
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize string
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Lindemann Lindemann audiotechnik GmbH [http://www.lindemann-audio.de/](http://www.lindemann-audio.de/%3C/manufacturerURL%3E) Limetree Network Limetree Network 000000 [http://www.lindemann-audio.de/](http://www.lindemann-audio.de/%3C/modelURL%3E) uuid:94d27917-b468-4222-b0df-2789324f82b3 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay [http://192.168.0.10:80/](http://192.168.0.10/%3C/presentationURL%3E) DMR-1.50
UPnP devices found : 1
Device #0: ID 0x0 Lindemann UID: uuid:94d27917-b468-4222-b0df-2789324f82b3 Location: http://192.168.0.10:50863/94d27917-b468-4222-b0df-2789324f82b3.xml
Max. memory for audio buffers: 1758MB
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:28 UID: AppleHDAEngineOutput:1B,0,1,1:0
I’m having the same problem with playing Qobuz tracks. Only the first track I choose from a playlist or album plays, then I must choose the second track manually for it to play and so on.
macOS 10.15.6 with 8192MB RAM
Registered to Lee Phifer
iZotope SRC custom frequencies iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat Jun 1 22:55:13 2019
Library database path: /Users/leephifer/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as FREE
Preferred device: LSX 021C0B Model UID:KEF LSX 021C0B UID:uuid:5f9ec1b3-ed59-1900-4530-841715021c0b
Currently playing to UPnP device at 24 bits 96kHz
UPnP device at http://192.168.8.103:9197/dmr
ID 0x0 [TV] Samsung 7 Series (49) Manufacturer:Samsung Electronics
Model UID:Samsung Electronics [TV] Samsung 7 Series (49) UID:uuid:50250950-32cf-49ae-a1f6-121e6487b7e1
Volume control: No
UPnP/DLNA supported protocols:Need to start playback to retrieved them
DLNA 1.5: Yes
Can play native DSD: No
2 virtual formats:
0 physical formats
NrTracks: 0
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK,NONE
<?xml version="1.0"?> 1 0 Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Stop InstanceID in A_ARG_TYPE_InstanceID Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks 0 MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData X_PrefetchURI InstanceID in A_ARG_TYPE_InstanceID PrefetchURI in A_ARG_TYPE_PrefetchURI PrefetchURIMetaData in A_ARG_TYPE_PrefetchURIMetaData GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition X_GetStoppedReason InstanceID in A_ARG_TYPE_InstanceID StoppedReason out A_ARG_TYPE_StoppedReason StoppedReasonData out A_ARG_TYPE_StoppedReasonData X_PlayerAppHint InstanceID in A_ARG_TYPE_InstanceID UpnpClass in X_ARG_TYPE_UpnpClass PlayerHint in X_ARG_TYPE_PlayerHint TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED OK TransportPlaySpeed string 1 NumberOfTracks ui4 0 4294967295 0 CurrentMediaDuration string 00:00:00 AVTransportURI string AVTransportURIMetaData string PlaybackStorageMedium string NONE NETWORK NONE CurrentTrack ui4 0 4294967295 1 0 CurrentTrackDuration string 00:00:00 CurrentTrackMetaData string CurrentTrackURI string RelativeTimePosition string 00:00:00 AbsoluteTimePosition string 00:00:00 NextAVTransportURI string NextAVTransportURIMetaData string CurrentTransportActions string RecordStorageMedium string NOT_IMPLEMENTED NOT_IMPLEMENTED RecordMediumWriteStatus string NOT_IMPLEMENTED NOT_IMPLEMENTED RelativeCounterPosition i4 2147483647 AbsoluteCounterPosition i4 2147483647 PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL CurrentRecordQualityMode string NOT_IMPLEMENTED NOT_IMPLEMENTED LastChange string A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_PrefetchURI string A_ARG_TYPE_PrefetchURIMetaData string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME ABS_COUNT REL_COUNT X_DLNA_REL_BYTE FRAME REL_TIME A_ARG_TYPE_SeekTarget string X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize string A_ARG_TYPE_StoppedReason string A_ARG_TYPE_StoppedReasonData string X_ARG_TYPE_UpnpClass string object.item.imageItem object.item.audioItem object.item.videoItem X_ARG_TYPE_PlayerHint string load unload
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 MS_DigitalMediaDeviceClass_DMR_V001 Display.TV.LCD Multimedia.DMR DMR-1.50 [TV] Samsung 7 Series (49) Samsung Electronics http://www.samsung.com/sec Samsung TV DMR UE49KS7000 AllShare1.0 http://www.samsung.com/sec 08TP3SGHB03477D uuid:50250950-32cf-49ae-a1f6-121e6487b7e1 image/jpeg 48 48 24 /icon_SML.jpg image/jpeg 120 120 24 /icon_LRG.jpg image/png 48 48 24 /icon_SML.png image/png 120 120 24 /icon_LRG.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/control/RenderingControl1 /upnp/event/RenderingControl1 /RenderingControl_1.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/control/ConnectionManager1 /upnp/event/ConnectionManager1 /ConnectionManager_1.xml urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/control/AVTransport1 /upnp/event/AVTransport1 /AVTransport_1.xml urn:schemas-rvualliance-org:service:StreamSplicing:1 urn:upnp-org:serviceId:StreamSplicing /upnp/control/StreamSplicing1 /upnp/event/StreamSplicing1 /StreamSplicing_1.xml Tizen,Y2016,WebURIPlayable,NavigateInPause,ScreenMirroringP2PMAC=c2:97:27:52:75:ec,UHD_SCREEN,SerialNumber=08TP3SGHB03477D VEN_0105&DEV_VD0001
UPnP devices found : 2
Device #0: ID 0x0 LSX 021C0B UID: uuid:5f9ec1b3-ed59-1900-4530-841715021c0b Location: http://192.168.8.105:8080/description.xml
Device #1: ID 0x0 [TV] Samsung 7 Series (49) UID: uuid:50250950-32cf-49ae-a1f6-121e6487b7e1 Location: http://192.168.8.103:9197/dmr
Device #0: ID 0x2b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x34 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{2D4C-0D3A-01000600}
Hello @Noodle, can you start to play an album and post your debug info again? @LeeInLeith does the issue you have appear with your TV only or also with your LSX?
Hi, I have the same issue here - first sporadic - but after the latest update always. Sometimes the playback stops also later within other tracks… quite annoying.
Regards
Hi, same problem for me since update 3.5.45 .
Playing Qobuz Hi res on external Dac.
Playback stops at the end of every track, sometimes displays an error message.
Let me know if you need more datas to analyse.
Here is an extract of debug :
2021-04-03 11:44:55,541 [4] DEBUG Audirvana.App - Error reading FLAC file https://streaming-std.qobuz.com/file?uid=642609&eid=114661252&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617446613&hmac=V2DFlL1iD3qHcAFxKfPvUo1_Ess : FLAC__STREAM_DECODER_END_OF_STREAM
2021-04-03 11:44:55,541 [4] DEBUG Audirvana.App - Fatal error reading audio file https://streaming-std.qobuz.com/file?uid=642609&eid=114661252&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617446613&hmac=V2DFlL1iD3qHcAFxKfPvUo1_Ess aborting loading at frame 0
2021-04-03 11:54:20,438 [1] INFO Audirvana.App - ============= Started Logging Audirvana 3.5.45 =============
2021-04-03 11:56:29,958 [15] DEBUG Audirvana.App - Error reading FLAC file https://streaming-std.qobuz.com/file?uid=642609&eid=446393&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617447339&hmac=OGJ7TnE64kmf6QQYDArVdkKqYSw : FLAC__STREAM_DECODER_END_OF_STREAM
2021-04-03 11:56:29,958 [15] DEBUG Audirvana.App - Fatal error reading audio file https://streaming-std.qobuz.com/file?uid=642609&eid=446393&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617447339&hmac=OGJ7TnE64kmf6QQYDArVdkKqYSw aborting loading at frame 0
2021-04-03 12:01:42,039 [9] DEBUG Audirvana.App - Error reading FLAC file https://streaming-std.qobuz.com/file?uid=642609&eid=446394&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617447613&hmac=UCcYyjD-TCyGqwB1O1M6KY0JW-U : FLAC__STREAM_DECODER_END_OF_STREAM
2021-04-03 12:01:42,039 [9] DEBUG Audirvana.App - Fatal error reading audio file https://streaming-std.qobuz.com/file?uid=642609&eid=446394&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617447613&hmac=UCcYyjD-TCyGqwB1O1M6KY0JW-U aborting loading at frame 0
2021-04-03 12:07:51,352 [28] DEBUG Audirvana.App - Error reading FLAC file https://streaming-std.qobuz.com/file?uid=642609&eid=446395&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617448002&hmac=exTyxU0pf1XEruIwQuMV4XkNvR0 : FLAC__STREAM_DECODER_END_OF_STREAM
2021-04-03 12:07:51,352 [28] DEBUG Audirvana.App - Fatal error reading audio file https://streaming-std.qobuz.com/file?uid=642609&eid=446395&fmt=7&profile=raw&app_id=866251341&cid=898833&etsp=1617448002&hmac=exTyxU0pf1XEruIwQuMV4XkNvR0 aborting loading at frame 0
Hello @Stefijah,
Hi,
Sorry for late response, here it is :
Audirvana 3.5.45
SW volume control: ON
AUTO: D:\sons
Library database path: C:\Users\Stef\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1388MB
Local Audio Engine:WASAPI
Haut-parleurs (Schiit Modi 3)
Model UID:Haut-parleurs (Schiit Modi 3)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b33194a0-9a75-4b0b-9a08-83edbc473f57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Haut-parleurs (Schiit Modi 3) Manufacturer:
Model UID:Haut-parleurs (Schiit Modi 3) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b33194a0-9a75-4b0b-9a08-83edbc473f57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Local devices found : 6
Device #0: Haut-parleurs (Schiit Modi 3) Manufacturer: Model UID: Haut-parleurs (Schiit Modi 3) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b33194a0-9a75-4b0b-9a08-83edbc473f57}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Casque pour téléphone (Jabra Evolve 65) Manufacturer: Model UID: Casque pour téléphone (Jabra Evolve 65) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d686aade-9cae-4d0c-b9cc-c63b28e0afac}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Haut-parleurs / écouteurs (Realtek® Audio) Manufacturer: Model UID: Haut-parleurs / écouteurs (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0dc91b89-eef0-4de8-93d7-7611fa774067}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: DELL S2340L (Son Intel® pour écrans) Manufacturer: Model UID: DELL S2340L (Son Intel® pour écrans) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4135af2e-8f85-4ca0-b08a-d4eef3319a6c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: Casque pour téléphone (Jabra Link 370) Manufacturer: Model UID: Casque pour téléphone (Jabra Link 370) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ce2baba3-ca4a-47bc-ba0c-fee6c6066d50}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #5: DELL S2340L (Son Intel® pour écrans) Manufacturer: Model UID: DELL S2340L (Son Intel® pour écrans) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3fb82347-c984-4a1d-b422-3e61c063736c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #0chambre bas UID: uuid:9ab0c000-f668-11de-9976-ac44f2861232 Location: http://192.168.0.14:49154/MediaRenderer/desc.xml
Damien,
It appears I am not the only one to get this issue. It looks like a caching problem since version 45.
I have made some more tests tonight :
Changing memory size
Changing upsampling
Same thing…
kr,
Stephane
Do you have the same issue if you deactivate upsampling?
Hi, it tested that on my side - but it does not play any role.
Only - the buffer size changes the time when the playback stops…
Regards
Sebastian
Hi,
Still an issue with upsampling deactivated, but the behavior is slightly different :
It seems that the playback goes to the end of the track, displays the name of the following song. But the following song never starts.
Stéphane
Do you have the same behavior if you select Haut-parleurs / écouteurs ?
Hi Damien,
Exactly the same behavior with any other output.
kr,
Stéphane
Hi Damien,
Any news by any chance ?
Stéphane
New user here and I also have the same problem of not being able to play songs continuously when they are in resolutions of 24/96 or 24/192. Here is my debug info;
Audirvana 3.5.45
Sync list: 2 folders
AUTO: C:\Users\mstil\Music
AUTO: E:\Music
Library database path: C:\Users\mstil\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1988MB
Speakers (Schiit Modi 3)
Model UID:Speakers (Schiit Modi 3)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{4bf25be4-0597-4ccf-8ede-447499143e3a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (Schiit Modi 3) Manufacturer:
Model UID:Speakers (Schiit Modi 3) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{4bf25be4-0597-4ccf-8ede-447499143e3a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #0: Speakers (Realtek® Audio) Manufacturer: Model UID: Speakers (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ba0d64ef-2cf0-46d2-a8a8-04cb7ebac799}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Schiit Modi 3) Manufacturer: Model UID: Speakers (Schiit Modi 3) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4bf25be4-0597-4ccf-8ede-447499143e3a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Now it won’t play Qobuz in high res at all. I can only play in 16/44 no matter what settings I use. Here is the debug info:
Audirvana 3.5.45
AUTO: E:\Music
Headphones (REIYIN Audio DA-02)
Model UID:Headphones (REIYIN Audio DA-02)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f33a3f19-6114-4ad7-b8ea-9e33cd563163}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Headphones (REIYIN Audio DA-02) Manufacturer:
Model UID:Headphones (REIYIN Audio DA-02) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f33a3f19-6114-4ad7-b8ea-9e33cd563163}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Device #0: Headphones (REIYIN Audio DA-02) Manufacturer: Model UID: Headphones (REIYIN Audio DA-02) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f33a3f19-6114-4ad7-b8ea-9e33cd563163}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Realtek® Audio) Manufacturer: Model UID: Speakers (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ba0d64ef-2cf0-46d2-a8a8-04cb7ebac799}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Do you have the same issue when you select Speakers (Realtek® Audio) ?
