I need a vst plugin that has at least 3 fully parametric bands and a shelving high and low bands. I don’t mind spending a little dough. I use Audeze LCD i4 in ears which are fantastic, but require specific eq to sound their best.
Any ideas or suggestions?
Mike
This plug-in is aimed at professionals and priced as such, but it’s simply mind blowingly good:
FabFilter Pro-Q 3
I have an semi-audiophile-grade setup, so I didn’t mind spending the $ on the EQ as it makes a big difference with my Hifiman Arya headphones.
If you search their forums you can ask for a 10% off coupon, which helps a little bit with the price.
Also for quality but less money take a look here:
Free trial.
And more on this topic in our forum here:
I bought Voxengo and I find it satisfactory
Thanks, guys. I have the demo’s of the FabFilter and the Voxengo. The Voxengo sounds good and is easy to use. The FabFilter sounds great but there is more of a learning curve. I’ll probably get the FabFilter.
