I have tried the fixes by going to Terminal. This didn’t work, so removed the file from the PrivilegedHelperTools, nothing was in LaunchDaemons when I came to remove. Shut down Mac and went into Audirvana and reinstalled the Sys Optimizer. This all worked fine, until I shut down and came back to it today. Played the first album fine, then subsequently when I press play it comes up with the error again.
Yes same, I did the update to 11.2.1 last night and the error has disappeared, so all good now. As an aside I have Time Machine, but do not have it activated. I only backup when I am going to so something major, so don’t think that was causing the issue. Thanks for responding though Damien, very much appreciated and thank you for all the great work you do on this amazing product
Nope. I actually went and disabled each option, restarted and tried again, uninstalling and installing many times. I get the same prompt each time, but it fails with the same error message. When I take a look at the directories being referenced as well there is nothing in those paths pertaining to Audirvana. I took a look at the Application contents actually just to ensure that it’s actually there, but I’m not sure what’s going on.
Obviously in the package contents themselves SysOptimizerTool is there, does it make a difference If I manually place that In a directory or?
Yes, com.audirvana.SysOptimizerTool is there now. But as soon as I go to press play on any song it will initiate the process to install SysOptimizer again and will fail.
Error Code: There was an error executing SysOptimizer. Not all optimizations may be done.
Error = The operation couldn’t be completed. (CFErrorDomainLaunchd error 4.)
Okay, let’s try another thing, can you close Audirvana and do the three commands below in Terminal?
sudo launchctl load -w /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
sudo rm /Library/PrivilegedHelperTools/com.audirvana.SysOptimizerTool
sudo rm /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
After doing this, can you open Audirvana and play a track?
getattrlist failed for /Library/GPUBundles/AppleIntelCFLGraphicsVAME.bundle/Contents/MacOS/AppleIntelCFLGraphicsVAME: #2: No such file or directory
getattrlist failed for /Library/GPUBundles/AppleIntelKBLGraphicsVADriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsVADriver: #2: No such file or directory
com.apple.xpc.launchd[1]: Coalition Cache Hit: app<application.com.audirvana.Audirvana.134781298.134781587(501)> [67857]
Now I’m getting this:
Error = The operation couldn’t be completed. (OSStatus error 22.)
