Audrivana keeps opening System Preferences on start-up, even though it is already in Accessibility as being able to access iTunes. Also, the keyboard already works. Can I stop this repeated message, please?
After opening Audirvana play an album. Stop it but still select the album. Close Audirvana. Start aagain Audirvana and it should begin with the afore named album.
Iâve tried what you suggested: Albums, songs, playlists, but it still opens System Preferences at start-up. Is it because Audirvana is already in âAutomationâ as having access to iTunes that I canât put it in âAccessibilityâ?
Close Audirvana, remove it from those places in system preferences with the minus sign⊠restart mac, go to system preferences and add it on both places with plus sign⊠open Audirvana and see
Thanks, but Mojave has moved Audirvana to Automation, instead of Accessibility. Automation does not have the +/- signs that Accessibility does, so I canât remove it.
Audrivana continue dâouvrir les PrĂ©fĂ©rences SystĂšme au dĂ©marrage, mĂȘme si AccessibilitĂ© est dĂ©jĂ disponible pour pouvoir accĂ©der Ă iTunes. En outre, le clavier fonctionne dĂ©jĂ . Puis-je arrĂȘter ce message rĂ©pĂ©tĂ©, sâil vous plaĂźt?
Pouvez vous rĂ©initialiser vos fichiers prĂ©fĂ©rence Audirvana? Pour cela vous devez entrer les deux commandes suivantes dans lâapplication Terminal:
defaults delete com.audirvana.Audirvana-Plus
Damien, merci dâavoir rĂ©pondu. Câest ce que je reçois dans le terminal. Y a-t-il un autre moyen de changer les prĂ©fĂ©rences?
Last login: Wed Dec 4 11:32:30 on ttys000
Christophers-MacBook-Pro-2:~ christopherphilipprzygoda$ defaults delete com.audirvana.Audirvana-More
2019-12-04 11:32:56.339 defaults[2318:291753]
Domain (com.audirvana.Audirvana-More) not found.
Defaults have not been changed.
313/5000
Suite Ă votre suggestion: La rĂ©initialisation sur Terminal rĂ©initialise tout dans Audirvana, Ă lâexception des PrĂ©fĂ©rences SystĂšme au dĂ©marrage. Aucun problĂšme, mais je voudrais me dĂ©barrasser de lâinvite PrĂ©fĂ©rences SystĂšme. Merci pour votre logiciel gĂ©nial. Je ne pensais pas que mon systĂšme de son pouvait mieux paraĂźtre. Christopher Przygoda
@Boulist, avez-vous modifié la commande? il ne dois pas y avoir more à la fin mais Plus pour que la commande fonctionne correctement
Je lâai mis correctement, mais la commande ne fonctionne pas. Câest peut-ĂȘtre Mojave, mais il nâa pas ce problĂšme avec mon autre macbook. Tout le reste va bien; pas de problĂšme.
pouvez-vous nous donner le résultat de la commande lorsque vous la lancez dans Terminal comme vous avez fait dans le message précédent ma derniÚre réponse?
Certainement. Merci.
Last login: Fri Dec 6 09:56:20 on ttys000
2019-12-07 10:40:19.407 defaults[3222:309079]
Recopie la premiĂšre rĂ©ponse de Damien⊠la tienne est pas bonne⊠pas more Ă la finâŠ
Damien, Merci dâavoir essayĂ© de rĂ©soudre ce problĂšme, mais comme vous pouvez le voir, jâai essayĂ©:
default remove com.audirvana.Audirvana-More
also,
default remove com.audirvana.Audirvana-Plus
Aucun de ces travaux, car lorsque jâouvre Audirvana, il me demande toujours dâouvrir les PrĂ©fĂ©rences SystĂšme. Cela nâaffecte pas la lecture de la musique ou le son, mais câest ennuyeux.
RunHomeSlow, veuillez lire les rĂ©ponses avant de mettre les vĂŽtres, car elles ne sont pas pertinentes pour ce que jâessaie de corriger.
Cordialement, Chris
Oui elle Ă©tait pertinente, car comme Damien te le disais, tu ne copiais pas les bonnes affairesâŠ
Comme tu as de la misĂšre avec le Terminal, tu peux essayer Ă la main de jeter tes prĂ©fĂ©rences dâAudirvana et AccessibilitĂ© en plusâŠ
Apple hide the Home Folder in User Library at some time depending on OS SystemâŠ
just do a ââcmd Jââ to show the folder settings preferences and see at the bottomâŠ
click Show Library Folder and then youâll have access to the rest forever.
Close Audirvana.
Go to User⊠Home Folder⊠Library⊠PreferencesâŠ
trash com.audirvana.Audirvana-Plus.plist and com.audirvana.Audirvana.plist
(those are A+ software preferences) and also in the same folder trash
com.apple.Accessibility.plist
Restart Mac. Restart Audirvana.
Merci pour votre aide, mais comme vous pouvez le voir sur les captures dâĂ©cran, il nây a rien dans lâaccessibilitĂ©, seulement dans lâautomatisation. Jâai suivi toutes vos instructions - Ă la lettre. Je nâai pas dâespace aprĂšs mon entrĂ©e dans Terminal, comme vous pouvez le voir sur la copie que jâai mise ici; peut-ĂȘtre que je fais quelque chose de mal.
Ce nâest quâun petit problĂšme, mais ennuyeux, car jâutilise uniquement ce macbook pour Audirvana et VLC. Mon autre macbook nâa pas ce problĂšme, car il a Audirvana dans Accessibility AND Automation.
Encore merci pour vos efforts. Je voudrais résoudre ce problÚme, mais il est mineur par rapport à ce que propose ce logiciel. TrÚs, trÚs impressionnant.
Cordialement, Chris
Vous avez cliquĂ© le cadenas au bas Ă gauche pour dĂ©verrouiller les prefs et ensuite soit ajouter Audirvana ou lâenlever dans automatisation ?
248/5000
Jâai essayĂ© cela il y a quelque temps, mais Mojave dans les PrĂ©fĂ©rences SystĂšme nâa pas la possibilitĂ© de supprimer quoi que ce soit de Automation. Le +/- nâest pas lĂ , comme dans la derniĂšre capture dâĂ©cran, mais il est dans lâaccessibilitĂ©. Je ne pensais pas que ce serait si difficile
[Send feedback](javascript:void(0)
History
Saved
OK⊠je crois que vous utilisĂ© iTunes avec Audirvana? câest pour ça quâil est dans automationâŠ
ce nâest pas votre bugâŠ
RetournĂ© dans accessibiltĂ© et dĂ©barrĂ© le cadenas et ensuite dĂ©cochĂ© Audirvana. RedĂ©marrez votre Mac, ensuite ouvrir Audirvana et voir si vous avez le message⊠si oui, ajoutez le dans accessibilitĂ©, si pas de message, allez-y vous mĂȘme avec le signe +âŠ
par la suite quitté Audirvana et le reouvrir pour voir si le message reviens.
