I get this error after 45 minutes or so of playing Tidal tracks normally. What happens is that, after this time, the next track refuses to load and I have to restart (and login) to Studio. I have the latest version. This did not happen on the 3.4 version of the software. While I am at it, why does the login window not remember my details?
Here is the debug log:
Current version: 1.6.1 (10601)
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 2 folders
AUTO: F:\Music\DSD
AUTO: \MARIELU\music\CD
Library database path: C:\Users\sjgra\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.154 on port 56830
Max. memory for audio buffers: 1692MB
Local Audio Engine: WASAPI
Speakers (CA USB Audio)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{839f9472-12d8-45e9-90d6-2cd926bb7186}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 96kHz
Manufacturer: Microsoft
Model Name: Speakers (CA USB Audio)
Model UID: MMDEVAPI\AudioEndpoints
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{839f9472-12d8-45e9-90d6-2cd926bb7186}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
9 available sample rates up to 705600Hz
Simple stereo device: No
Local devices found : 3
Device #0: Speakers (CA USB Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{839f9472-12d8-45e9-90d6-2cd926bb7186}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers (CA USB Audio)
Device #1: Speakers / Headphones (Realtek Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ecc6cb47-f3e6-44a5-83d3-09dcdef48ade}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers / Headphones (Realtek Audio)
Device #2: DELL S2817Q (Intel(R) Display Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ba0d6a40-4c3a-4425-8d23-5e3e08c78318}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: DELL S2817Q (Intel(R) Display Audio)
UPnP devices found : 2
Device #0Squatty UID: uuid:1af97eda-f9ce-45af-9f7f-70a688489a00 Location: http://192.168.1.185:8050/1af97eda-f9ce-45af-9f7f-70a688489a00/description.xml
Device #1[TV] Living room UID: uuid:08f0d182-0096-1000-bf66-fcf1367931b9 Location: http://192.168.1.76:7676/smp_15_
