Hello @henryv, it’s done for your too
Super! Vraiment très rapide, merci.
I also forgot (again) to deactivate prior to a fresh install. Can my macs also be removed from the database?
Thanks.
Michael
Hello @Antoine
I have just installed a new SSD with a fresh Windows instal. I did not uninstall Aurdirvana from my HDD (still being used for storage). Please could you revoke my previous Windows license so that I can reinstall on my new set-up?
Many thanks
Alan
Hello @alan84,
I have removed all your computers from the license database.
You can now activate up to two computers.
To install Audirvana on your computers, you can proceed as follows:
- install trial version : https://audirvana.com/try/
- unlock it by loading your license key
Hello.
After the last Audirvana update to version 3.5.38 my license key has stopped working.
Immediately after the update, a message appeared about entering the license key.
After entering the key, everything was fine.
Today, the message requesting a license key has appeared again,
unfortunately after entering it, information appears that the license key
has been used too many times.
I’ve been using Audirvana on one computer from the very beginning.
Please remove all my computers from the licence database.
I uninstalled the Audirvana without deactivatin, Windows 10 OS
Hello @arek12320,
You can now activate up to two PC running Windows 10.
To install Audirvana on your PC, you can proceed as follows:
- install trial version : https://audirvana.com/try-windows/
Thank you .
Best regards.
Hi Damien3,
I have the sam problems as users above, could You please help me?
Hello @Seweryn_Cieslik,
You can now activate up to two Mac computers.
To install Audirvana on your Mac, you can proceed as follows:
- install trial version : https://audirvana.com/try-mac/
Hi Damien,
Can you please remove my Old PC that died so i can use Audirvana on my new PC?
Im getting the “too many install” message.
My version is for Windows 10.
Thanks so much!
Hello @eder.pereira1,
Hi Damien,
I sent you a pm I replaced my old mac over 10 years old with a new one just got I did the de-authorize and uninstall waited 24hrs on my new mac but got the too many licenses on 1 of your computers.
Thank you,
Kurb1980
Hi Damien3,
I have same problem about my account activation.
Please remove my old license.
Best regards.
Hello @fussan,
Damien3
Thank you very much.
And sorry for my request wrote in incorrect place.
Best regards.
Hello,
i have the same problem!
(mac & windows)
Best regards.
Hello @kyseo,
It’s done for your too, you can now use Audirvana up on two activations for Windows 10 and/or MacOS.
I have the same issue and getting too many activations error, could you please reset.
Thank you
