Hello @Soarix, @rdad and @lygiaikhanh, It’s done for you. I removed your computers in our database, you can now activate audirvana up on two computers.
Same issue for me @Antoine. Please clear the database so I can assign the license key to my two computers.
Hej damien3 har köpt en nyckel .kan inte aktivera den .kommer inte in mvh peter
Could you please remove all my computers so I can make a fresh license devision with my pc’s at least 1 pc is broken and can’t be deactivated anymore
Hello @mitsu600,
I have removed all your computers from the license database.
You can now activate up to two Mac computers you want with your license key.
To install Audirvana on your second Mac, you can proceed as for the first one:
- install trial version
- unlock it by loading your same license key
hej jag har köpt en lisence .nu kan jag inte komma in på audirvana för att jag har försökt för många gånger . jag har köpt stereo grejer för 300000 och vill ha max audio fil .kan du hjälpa mig att att få in min lisence
Please remove all my computers from the licence database.
I uninstalled the Audirvana without deactivatin, and I reinstalled Windows 10 OS.
I have the same problem. Please remove all my comuters from the licence database.
Hello @nari, @akira and @musical, it’s done for all of your. You now activate Audirvana up on two computers.
I uninstalled the Audirvana without deactivatin, Windows 10 OS.
Hello @YOTTYAN,
I have removed all your computers from the license database. You can now activate up to two PC running Windows 10.
To install Audirvana on your PC, you can proceed as follows:
- install trial version : https://audirvana.com/try-windows/
- unlock it by loading your license key
Thank you very much !!!
I uninstalled the Audirvana without deactivatin, and I reinstalled MACOS.
Please remove my computers too. Cant activate it anymore.
Hello @Bugs,
Can you delete all my computers from the license database? I have deinstalled Audirvana on all my computers but still get the message too many activations when I try to activate the license on my new computer.
