Track plays a few seconds and then skips to next track. Can be any track, often second one. Has lately only been happening when streaming Qobuz, not when playing files from local library. Has happened for 29 days.
Current version: 1.6.1 (10601)
VST3 plugin #0: C:\Program Files\Common Files\VST3\Marvel GEQ.vst3
ClassID: C40CD0E0899D4484BFB44A40B57B62C4
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: C:\Users\Jeff\Music\Music FLAC
Library database path: C:\Users\Jeff\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2603:6081:2c07:6b00:6448:9daf:3a2f:544f on port 49201
Max. memory for audio buffers: 15254MB
Local Audio Engine: WASAPI
Model UID:
UID:
Active Sample Rate: 48kHz
Speakers (5- D30)
Manufacturer: Microsoft
Model Name: Speakers (5- D30)
Model UID: MMDEVAPI\AudioEndpoints
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{1dca88dc-647f-4c78-9908-bdd851107faa}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Speakers (5- D30) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{1dca88dc-647f-4c78-9908-bdd851107faa}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers (5- D30)
UPnP devices found : 2
Device #0Denon AVR-S650H UID: uuid:8e00bd6b-431b-15b2-0080-0005cd7a60de Location: http://192.168.0.3:60006/upnp/desc/aios_device/aios_device.xml
Device #1[TV] Samsung 6 Series (55) UID: uuid:61f245e9-4083-4052-b957-e00ce147f75d Location: http://192.168.0.4:9197/dmr
