I’ve shifted over to a Mac Mini with 16gb of RAM running Catalina. Running this with a Topping E30 DAC with everything configured correctly.
The problem is: when I start up Audirvana, the first few tracks load fine and starts playing. After changing a few tracks, the software breaks and is not able to get past the 0:00 mark of all following tracks. I’ve tried everything - changing pre-load memory, upsampling, volume adjustments and OS update. Nothing is working. This is extremely frustrating. I’m still within my trial period and am having second thoughts of actually paying for Audirvana when it barely worked on my PC and Mac. Can anyone point me in the right direction? Please.
Here’s my debug info:
AUTO: /Volumes/Music - FLAC/
Library database path: /Users/jlhipower/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 9134MB
E30
Model UID:E30:152A:8750
UID:AppleUSBAudioEngine:Topping:E30:24400000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x29 E30 Manufacturer:Topping
Model UID:E30:152A:8750 UID:AppleUSBAudioEngine:Topping:E30:24400000:1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x38 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x41 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutputDP:8,5,1,0:0:{104D-0000-000009F8}
Device #2: ID 0x29 E30 Manufacturer: Topping Model UID: E30:152A:8750 UID: AppleUSBAudioEngine:Topping:E30:24400000:1
UPnP devices found : 2
Device #0: ID 0x0 [LG] webOS TV UJ6200 UID: uuid:27625086-5b68-0765-5d3e-a613172f98ab Location: http://192.168.1.9:1521/
Device #1: ID 0x0 Home Theatre UID: uuid:9ab0c000-f668-11de-9976-946ab0943bd0 Location: http://192.168.1.45:49154/MediaRenderer/desc.xml
