I use Windows desktop sharing system to control Audirvana Origin from another PC. This usually works, but lately the Unhandled exception error, repeatedly over and over makes a mess, and remote desktop freezes.
How to remove this nuisance HRESULT: 0x80263001 ?
Running Windows 10 LTSC
We may have experienced a similar problem.
Could you please send logs to their technical support?
support@audirvana.com
Hi @One-and-a-Half,
Can you send us your audirvana.dmp and audirvana.log file at support@audirvana.com?
to show AppData folder:
Replied with apology August 5
