Damien,
3.5.20 may have broken this, again. I’m having the same issue as before, where my Sonore Ultrarendu is not being found as a UPnP device. However, Audirvana does recognize my Samsung TV. I was listening to Audirvana last night. I’ve done all the standard troubleshooting and nothing has worked. Last I new, I was running 3.5.18.4 on my MacBook Pro and it’s been running fine since I upgraded to it, about a month ago. I’m currently running Audirvana Mac Version 3.5.20 (3550). macOS 10.14.6 with 16384MB RAM. Is is setup to autoupdate, because I didn’t initiate an upgrade (just for this reason). Help!
Registered to John Bilos
Sync list: 0 folders
Library database path: /Users/johnbilos/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
MacBook Pro Speakers
Model UID:Speaker
UID:BuiltInSpeakerDevice
Active Sample Rate: 48kHz
ID 0x45 MacBook Pro Speakers Manufacturer:Apple Inc.
Model UID:Speaker UID:BuiltInSpeakerDevice
Stream ID 0x46 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x45 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 [TV] Samsung The Frame (55) UID: uuid:125008e1-1fa6-4654-97d1-cc89a2117647 Location: http://192.168.190.199:9197/dmr
