Thanks, but your hardware/OS configuration is vastly different than mine. We’re trying to drill down whether it’s a Sonoma or M2 issue, really. As I said, I “think” the issue was not present on my M1 Ultra Studio running Ventura.
Audirvana Origin 2.5.10 (20510)
macOS Version 14.3 (Build 23D56) with 192GB physical RAM
Connected account of : redacted
No plugin active
Max allowed volume: 44.7483
Replay Gain: by album
Sync list: 5 folders
AUTO: /Users/redacted/Music/NEW trax/7digital
AUTO: /Users/redacted/Music/NEW trax/DSD
AUTO: /Users/redacted/Music/NEW trax/FLAC
AUTO: /Users/redacted/Music/NEW trax/ProStudioMasters
AUTO: /Users/redacted/Music/NEW trax/The Fellowship of the Ring Complete - 24bit 48KHz 5.1 DVD-A (FLAC)
iTunes/Music library synchronization: last synchronized on Sun Dec 24 17:01:05 2023
Library database path: /Users/redacted/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50088
Max. memory for audio buffers: 61934MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Lynx Studio Technology, Inc. 1: Lynx AES16e
Model UID:LynxAudioDevice-Model010028
UID:LynxAudioDevice-UID010028
Active Sample Rate: 192kHz
Selected device:3: Hilo-TB3
Manufacturer: Lynx Studio Technology, Inc.
Model name: Lynx Studio Technology, Inc. 3: Hilo-TB3
Model UID: LynxAudioDevice-Model033116
UID: LynxAudioDevice-UID033116
ID 0x7a
Audio buffer frame size : 58 to 3072 frames
Multichannel: 16 channels
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Channel 6 unused
Channel 7 unused
Channel 8 unused
Channel 9 unused
Channel 10 unused
Channel 11 unused
Channel 12 unused
Channel 13 unused
Channel 14 unused
Channel 15 unused
Number of channels: 16
Simple stereo device: No
8 output streams:
Number of active channels: 16, in 8 stream(s)
Channel #2 :Stream 1 channel 0
Channel #3 :Stream 1 channel 1
Channel #4 :Stream 2 channel 0
Channel #5 :Stream 2 channel 1
Channel #6 :Stream 3 channel 0
Channel #7 :Stream 3 channel 1
Channel #8 :Stream 4 channel 0
Channel #9 :Stream 4 channel 1
Channel #10 :Stream 5 channel 0
Channel #11 :Stream 5 channel 1
Channel #12 :Stream 6 channel 0
Channel #13 :Stream 6 channel 1
Channel #14 :Stream 7 channel 0
Channel #15 :Stream 7 channel 1
Stream ID 0x7b 2 channels starting at 1
6 virtual formats:
6 physical formats
Stream ID 0x7c 2 channels starting at 3
6 virtual formats:
6 physical formats
Stream ID 0x7d 2 channels starting at 5
6 virtual formats:
6 physical formats
Stream ID 0x7e 2 channels starting at 7
6 virtual formats:
6 physical formats
Stream ID 0x7f 2 channels starting at 9
6 virtual formats:
6 physical formats
Stream ID 0x80 2 channels starting at 11
6 virtual formats:
6 physical formats
Stream ID 0x81 2 channels starting at 13
6 virtual formats:
6 physical formats
Stream ID 0x82 2 channels starting at 15
6 virtual formats:
6 physical formats
Local devices found : 6
Device #0: ID 0x76 Blackmagic Intensity Pro 4K
Manufacturer: Blackmagic Design
Model UID: Intensity Pro 4K
UID: 75:395ac604:00000000:Audio
Model name: Blackmagic Design Blackmagic Intensity Pro 4K
Device #1: ID 0x3d Studio Display Speakers
Model UID: Studio Display Audio Control:05AC:1114
UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-000A79161AE0802E:8,9
USB Vendor ID: 0x05ac
USB Product ID: 0x1114
Model name: Apple Inc. Studio Display Speakers
Device #2: ID 0x33 LG UltraFine Display Audio
Manufacturer: LG Electronics Inc.
Model UID: LG UltraFine Display Audio:043E:9A66
UID: AppleUSBAudioEngine:LG Electronics Inc.:LG UltraFine Display Audio:7241000:2
USB Vendor ID: 0x043e
USB Product ID: 0x9a66
Model name: LG Electronics Inc. LG UltraFine Display Audio
Device #3: ID 0x70 Mac Studio Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Mac Studio Speakers
Device #4: ID 0x7a 3: Hilo-TB3
Device #5: ID 0x47 Aggregate Device
Model UID: ~:AMS2_Aggregate:0
Model name: Apple Inc. Aggregate Device
