Using Fidelizer with Audirvana on Windows 11
those familiar with Fidelizer may be aware it offers the option to start your audio player with a high process priority. I can do that with Foobar2000, but I haven’t figured out where the Audirvana executable is stored, and I see an old thread from 2019 that says it’s not possible.
Has anything changed now? Can Audirvana be started from Fidelizer? Is there another way to start Audirvana with a high process priority?
Try the solution offered in the linked thread. Not a windows user but this would appear to be exactly what you are trying to do……
