Apologies for similar post, but since I’m on mac not windows, I started a new thread.
On the Audirvana main page (library), it is very very slow to scroll the albums, and I get the spinning beach ball very often. If I am listening to music, it cuts out every now and then when it loads the albums / spinning beach ball.
I could live with it if it was only on Audirvana startup, but it happens consistently every time I am scrolling the library.
For me, it is the most annoying problem with Audirvana. Yes, there are feature requests I would like to see, and tweaks here and there, but this really makes it difficult to use Audirvana.
Is there anything I can do?
Audirvana version 3.5.40
MacOS 10.15.7
iMac Late 2015, 3.2 GHz Quad-Core Intel Core i5, 24GB RAM
Audirvana stored on internal SSD, music files on external HDD (usb 3.0)
I have tried usual troubleshooting: check database, rebuild database, defragmemt
I have about 320 albums, mostly DSD. the sqlite file is just under 500mb.
I have 13GB allocated in Audirvana for pre-load, exclusive access, large core i/o , integer mode all set to ON
Any suggestions would be of great help. I would just like to be able to scroll the albums I have without it pausing every second and stopping the music currently playing.
Thank you!
