macOS 10.13.6 with 16384MB RAM
Registered to Diego Martinez Bonati Diego
AUTO: /Users/Diego/Desktop
Library database path: /Users/Diego/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4008MB
SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x1ad SMSL USB AUDIO Manufacturer:SMSL
Model UID:SMSL USB AUDIO:152A:85DD UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
Stream ID 0x1ae 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 8
Device #0: ID 0x153 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:40 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x1ad SMSL USB AUDIO Manufacturer: SMSL Model UID: SMSL USB AUDIO:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
Device #2: ID 0x1a4 MJAudioRecorder Manufacturer: MJ Audio Inc. Model UID: MJRecordDeviceModelUID UID: MJRecordDevice
Device #3: ID 0x19c MMAudio Device Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID UID: MMAudioDevice
Device #4: ID 0x1a1 MMAudio Device (UI Sounds) Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID_UISounds UID: MMAudioDevice_UISounds
Device #5: ID 0x18b Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #6: ID 0x164 Soundflower (16ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
Device #7: ID 0x196 ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001
