AS does not know to sort metadata
Super idea!!!
In addition, while ripping the vinyls, they were forced to listen to classical music, jazz, blues, progressive rock… instead of rap, hip-hop, techno and whatever genres they were listening usually. :smiley:
Even better!!!
Now that’s good parenting! :slight_smile:
Now that you people mention Audirvana’s problems reading tags, I discovered two albums in my collection that behave strangely. One is by Jim Hall (Concierto) and the other is Jimmy Giuffre 3 (Jimmy Giuffre). Both albums are not sorted alphabetically according to the artists second name. For the former, metadata looks really strange: The artist is listed as Jim Hall - Jim Hall, and the composers are totally wrong, even though they look perfectly fine in Yate. And Artist Sort in Yate is set to Hall, Jim.
It looks as if there is somewhere some information in the metadata file that overrides the data provided by Yate/MusicBrainz. Strange indeed!
These conflicts are exactly the sort of thing that has led me to request opt-out of the metadata analysis and/or allowing the user to specify only using native tags.
I agree completely with you. In addition, the profit of this analysis is very meager. Some rare bios with small fonts that are impossible to read. And the suggestions from the streaming providers. I don’t stream, so I have no opinion about it, but some users reported that these suggestions were an annoyance.
What are the metadata you see in Studio when you open the metadata editor of Studio when you see the album (without selecting a track in it)?
We understood this, you kept posting this on the forum since the release of Studio. We understand that the MusicBrainz analysis should be opt-out, that the font are too small and for your case you don’t stream. We get it and you don’t have to keep spamming this kind of post on and on.
Let us some time and we will do what you and other request.
I’m happy to see that you are reading what’s posted in the threads.
I did not know if it was the case, because you were absent during long weeks. That’s the reason that I repeat myself.
It will be a good thing, indeed, for AS to opt-out this analysis.
Thanks, Damien, for getting back to this reply!
The attached screenshots show the general metadata tab and the Infos tab. The Artwork tab, naturally, only contains the album cover.
Does that make sense?
To come back to your initial issue. When you tag a FLAC and DSF file, the tag scheme are really different between those two format. In FLAC you are using VORBIS comment which, depending on the tag editor, can add multiple artist in the same track.
In your case you have this in the Raw data of your the track you sent to me using Yate (you will there is effectively a space before Kempff):
You can see there is a second ARTIST and ALBUM ARTIST comment. Audirvana since 3.5 support multiple artist in the same album which explain why you see Menuhin, Yehudi and Kempff, Wilhelm as two album artist in Studio.
And for DSF file, if you look at a track Raw data in Yate for the album Beethoven: Late Choral & Gershwin [SACD] , what do you see?
Ok, can you send me the first track of this album at [email protected]?
I’m not sure to understand your answer.
Menuhin and Kempff are separated indeed in the “Artist” tag and the “Album Artist” tag with a “; + space”.
This is a FLAC album indeed, but it is not the only FLAC album in AS’ library in which the multiple artists are separated with “; + space”.
The second artist that is displayed by AS in “Artist View”, “Mackeras/Scottish…”, is also a FLAC album that uses this separation for the multiple artists, and the multiple “Album artists”.
As you can see in the screenshot, they are separated by “; + space”.
Nevertheless, for this album, AS removed the name of “Pizzaro” as an “Album Artist”, added a space in the beginning of the name “Mackeras”. But, unlike the album of “Menuhin & Kempff”, AS did not create for this album two separate “Album Artists” in “Artist View”.
I don’t know what I should look at the album “Beethoven: Late Choral & Gershwin [SACD]”, because I don’t understand what you mean by “Raw data”.
Can you open the Raw Data option in view to see if you have the multiple album artists in it?
If A3.5 supports multiple artists, why it reverses their order? AS does the same. It’s annoying, because the soloist, that is credited first in the tags, comes last in the display of the library, after the conductor and the orchestra.
It’s 75 MB, doable via mail?
If’s because it sorted it alphabetically. We are aware of this and we will work on it.
I opened the Raw Data of this album, but I don’t know at what should I look. So I paste for you what the Log viewer displayed.
This is for the album of “Mackeras…”
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/01 - Piano Concerto No 3 in C minor Op 37 - Allegro con brio.flac
Raw Data:
File size: 657732815
Sample size: 24 bit
Sample rate: 192000 Hz
Duration: 1025178 ms
Bit rate: 5132 kbits/sec VBR
Vendor: reference libFLAC 1.1.2 20050205
00000004 00000042 00000034 STREAMINFO
00000042 00001900 00001854 SEEKTABLE
00001900 00002546 00000642 VORBIS_COMMENT
00001944 TITLE
1944: 3e 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |>…TITLE=Piano Conc|
1964: 65 72 74 6f 20 4e 6f 2e 33 20 69 6e 20 43 20 6d 69 6e 6f 72 |erto No.3 in C minor|
1984: 2c 20 4f 70 2e 33 37 20 2d 20 41 6c 6c 65 67 72 6f 20 63 6f |, Op.37 - Allegro co|
2004: 6e 20 62 72 69 6f |n brio |
00002010 ARTIST
2010: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
2030: 41 72 74 75 72 |Artur |
00002035 ARTIST
2035: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
2055: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
2075: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
2095: 61 |a |
00002096 ALBUMARTIST
2096: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
2116: 72 72 6f |rro |
00002119 ALBUMARTIST
2119: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
2139: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00002157 ALBUM
2157: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
2177: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
2197: 69 7a 61 72 72 6f |izarro |
00002203 ALBUM
2203: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
2223: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00002236 TRACKNUMBER
2236: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 31 |…TRACKNUMBER=1 |
00002253 DATE
2253: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00002266 GROUPING
2266: 1b 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 33 37 |…GROUPING=Bn,op37|
2286: 20 43 50 20 23 33 20 69 6e 20 63 | CP #3 in c |
00002297 COMPOSER
2297: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
2317: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
2337: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00002357 GENRE
2357: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
2377: 6f |o |
00002378 TOTALTRACKS
2378: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00002395 COMMENT
2395: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
2415: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
2435: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
2455: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00002472 TOOL NAME
2472: 16 00 00 00 54 4f 4f 4c 20 4e 41 4d 45 3d 4d 65 64 69 61 20 |…TOOL NAME=Media |
2492: 43 65 6e 74 65 72 |Center |
00002498 TOOL VERSION
2498: 15 00 00 00 54 4f 4f 4c 20 56 45 52 53 49 4f 4e 3d 31 35 2e |…TOOL VERSION=15.|
2518: 30 2e 31 32 32 |0.122 |
00002523 TRACK_NUMBER_TEXT
2523: 13 00 00 00 54 52 41 43 4b 5f 4e 55 4d 42 45 52 5f 54 45 58 |…TRACK_NUMBER_TEX|
2543: 54 3d 31 |T=1 |
00002546 00141698 00139148 PICTURE
00141698 00184042 00042340 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/02 - Piano Concerto No 3 in C minor Op 37 - Largo.flac
Raw Data:
File size: 339098665
Sample size: 24 bit
Duration: 539520 ms
Bit rate: 5030 kbits/sec VBR
00000042 00001018 00000972 SEEKTABLE
00001018 00001653 00000631 VORBIS_COMMENT
00001062 TITLE
1062: 33 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |3…TITLE=Piano Conc|
1082: 65 72 74 6f 20 4e 6f 2e 33 20 69 6e 20 43 20 6d 69 6e 6f 72 |erto No.3 in C minor|
1102: 2c 20 4f 70 2e 33 37 20 2d 20 4c 61 72 67 6f |, Op.37 - Largo |
00001117 ARTIST
1117: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
1137: 41 72 74 75 72 |Artur |
00001142 ARTIST
1142: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
1162: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
1182: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
1202: 61 |a |
00001203 ALBUMARTIST
1203: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
1223: 72 72 6f |rro |
00001226 ALBUMARTIST
1226: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
1246: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00001264 ALBUM
1264: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
1284: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
1304: 69 7a 61 72 72 6f |izarro |
00001310 ALBUM
1310: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
1330: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00001343 TRACKNUMBER
1343: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 32 |…TRACKNUMBER=2 |
00001360 DATE
1360: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00001373 GROUPING
1373: 1b 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 33 37 |…GROUPING=Bn,op37|
1393: 20 43 50 20 23 33 20 69 6e 20 63 | CP #3 in c |
00001404 COMPOSER
1404: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
1424: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
1444: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00001464 GENRE
1464: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
1484: 6f |o |
00001485 TOTALTRACKS
1485: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00001502 COMMENT
1502: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
1522: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
1542: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
1562: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00001579 TOOL NAME
1579: 16 00 00 00 54 4f 4f 4c 20 4e 41 4d 45 3d 4d 65 64 69 61 20 |…TOOL NAME=Media |
1599: 43 65 6e 74 65 72 |Center |
00001605 TOOL VERSION
1605: 15 00 00 00 54 4f 4f 4c 20 56 45 52 53 49 4f 4e 3d 31 35 2e |…TOOL VERSION=15.|
1625: 30 2e 31 32 32 |0.122 |
00001630 TRACK_NUMBER_TEXT
1630: 13 00 00 00 54 52 41 43 4b 5f 4e 55 4d 42 45 52 5f 54 45 58 |…TRACK_NUMBER_TEX|
1650: 54 3d 32 |T=2 |
00001653 00140805 00139148 PICTURE
00140805 00183160 00042351 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/03 - Piano Concerto No 3 in C minor Op 37 - Rondo allegro.flac
Raw Data:
File size: 359496811
Sample size: 24 bit
Duration: 557963 ms
Bit rate: 5160 kbits/sec VBR
00000042 00001054 00001008 SEEKTABLE
00001054 00001697 00000639 VORBIS_COMMENT
00001098 TITLE
1098: 3b 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |;…TITLE=Piano Conc|
1118: 65 72 74 6f 20 4e 6f 2e 33 20 69 6e 20 43 20 6d 69 6e 6f 72 |erto No.3 in C minor|
1138: 2c 20 4f 70 2e 33 37 20 2d 20 52 6f 6e 64 6f 20 61 6c 6c 65 |, Op.37 - Rondo alle|
1158: 67 72 6f |gro |
00001161 ARTIST
1161: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
1181: 41 72 74 75 72 |Artur |
00001186 ARTIST
1186: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
1206: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
1226: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
1246: 61 |a |
00001247 ALBUMARTIST
1247: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
1267: 72 72 6f |rro |
00001270 ALBUMARTIST
1270: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
1290: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00001308 ALBUM
1308: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
1328: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
1348: 69 7a 61 72 72 6f |izarro |
00001354 ALBUM
1354: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
1374: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00001387 TRACKNUMBER
1387: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 33 |…TRACKNUMBER=3 |
00001404 DATE
1404: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00001417 GROUPING
1417: 1b 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 33 37 |…GROUPING=Bn,op37|
1437: 20 43 50 20 23 33 20 69 6e 20 63 | CP #3 in c |
00001448 COMPOSER
1448: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
1468: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
1488: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00001508 GENRE
1508: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
1528: 6f |o |
00001529 TOTALTRACKS
1529: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00001546 COMMENT
1546: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
1566: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
1586: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
1606: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00001623 TOOL NAME
1623: 16 00 00 00 54 4f 4f 4c 20 4e 41 4d 45 3d 4d 65 64 69 61 20 |…TOOL NAME=Media |
1643: 43 65 6e 74 65 72 |Center |
00001649 TOOL VERSION
1649: 15 00 00 00 54 4f 4f 4c 20 56 45 52 53 49 4f 4e 3d 31 35 2e |…TOOL VERSION=15.|
1669: 30 2e 31 32 32 |0.122 |
00001674 TRACK_NUMBER_TEXT
1674: 13 00 00 00 54 52 41 43 4b 5f 4e 55 4d 42 45 52 5f 54 45 58 |…TRACK_NUMBER_TEX|
1694: 54 3d 33 |T=3 |
00001697 00140849 00139148 PICTURE
00140849 00183196 00042343 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/04 - Piano Concerto No 4 in G major Op 58 - Allegro moderato.flac
Raw Data:
File size: 685797419
Sample size: 24 bit
Duration: 1075771 ms
Bit rate: 5102 kbits/sec VBR
00000042 00001990 00001944 SEEKTABLE
00001990 00002636 00000642 VORBIS_COMMENT
00002034 TITLE
2034: 3e 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |>…TITLE=Piano Conc|
2054: 65 72 74 6f 20 4e 6f 2e 34 20 69 6e 20 47 20 6d 61 6a 6f 72 |erto No.4 in G major|
2074: 2c 20 4f 70 2e 35 38 20 2d 20 41 6c 6c 65 67 72 6f 20 6d 6f |, Op.58 - Allegro mo|
2094: 64 65 72 61 74 6f |derato |
00002100 ARTIST
2100: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
2120: 41 72 74 75 72 |Artur |
00002125 ARTIST
2125: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
2145: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
2165: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
2185: 61 |a |
00002186 ALBUMARTIST
2186: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
2206: 72 72 6f |rro |
00002209 ALBUMARTIST
2209: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
2229: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00002247 ALBUM
2247: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
2267: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
2287: 69 7a 61 72 72 6f |izarro |
00002293 ALBUM
2293: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
2313: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00002326 TRACKNUMBER
2326: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 34 |…TRACKNUMBER=4 |
00002343 DATE
2343: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00002356 GROUPING
2356: 1b 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 35 38 |…GROUPING=Bn,op58|
2376: 20 43 50 20 23 34 20 69 6e 20 47 | CP #4 in G |
00002387 COMPOSER
2387: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
2407: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
2427: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00002447 GENRE
2447: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
2467: 6f |o |
00002468 TOTALTRACKS
2468: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00002485 COMMENT
2485: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
2505: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
2525: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
2545: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00002562 TOOL NAME
2562: 16 00 00 00 54 4f 4f 4c 20 4e 41 4d 45 3d 4d 65 64 69 61 20 |…TOOL NAME=Media |
2582: 43 65 6e 74 65 72 |Center |
00002588 TOOL VERSION
2588: 15 00 00 00 54 4f 4f 4c 20 56 45 52 53 49 4f 4e 3d 31 35 2e |…TOOL VERSION=15.|
2608: 30 2e 31 32 32 |0.122 |
00002613 TRACK_NUMBER_TEXT
2613: 13 00 00 00 54 52 41 43 4b 5f 4e 55 4d 42 45 52 5f 54 45 58 |…TRACK_NUMBER_TEX|
2633: 54 3d 34 |T=4 |
00002636 00141788 00139148 PICTURE
00141788 00184132 00042340 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/05 - Piano Concerto No 4 in G major Op 58 - Andante con moto.flac
Raw Data:
File size: 165284169
Sample size: 24 bit
Duration: 264938 ms
Bit rate: 5004 kbits/sec VBR
00000042 00000532 00000486 SEEKTABLE
00000532 00001104 00000568 VORBIS_COMMENT
00000576 TITLE
576: 3e 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |>…TITLE=Piano Conc|
596: 65 72 74 6f 20 4e 6f 2e 34 20 69 6e 20 47 20 6d 61 6a 6f 72 |erto No.4 in G major|
616: 2c 20 4f 70 2e 35 38 20 2d 20 41 6e 64 61 6e 74 65 20 63 6f |, Op.58 - Andante co|
636: 6e 20 6d 6f 74 6f |n moto |
00000642 ARTIST
642: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
662: 41 72 74 75 72 |Artur |
00000667 ARTIST
667: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
687: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
707: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
727: 61 |a |
00000728 ALBUMARTIST
728: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
748: 72 72 6f |rro |
00000751 ALBUMARTIST
751: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
771: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00000789 ALBUM
789: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
809: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
829: 69 7a 61 72 72 6f |izarro |
00000835 ALBUM
835: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
855: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00000868 TRACKNUMBER
868: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 35 |…TRACKNUMBER=5 |
00000885 DATE
885: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00000898 GROUPING
898: 1b 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 35 38 |…GROUPING=Bn,op58|
918: 20 43 50 20 23 34 20 69 6e 20 47 | CP #4 in G |
00000929 COMPOSER
929: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
949: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
969: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00000989 GENRE
989: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
1009: 6f |o |
00001010 TOTALTRACKS
1010: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00001027 COMMENT
1027: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
1047: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
1067: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
1087: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00001104 00140256 00139148 PICTURE
00140256 00142224 00001964 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/06 - Piano Concerto No 4 in G major Op 58 -Rondo vivace.flac
Raw Data:
File size: 376699401
Sample size: 24 bit
Duration: 590663 ms
Bit rate: 5105 kbits/sec VBR
00000042 00001126 00001080 SEEKTABLE
00001126 00001693 00000563 VORBIS_COMMENT
00001170 TITLE
1170: 39 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |9…TITLE=Piano Conc|
1190: 65 72 74 6f 20 4e 6f 2e 34 20 69 6e 20 47 20 6d 61 6a 6f 72 |erto No.4 in G major|
1210: 2c 20 4f 70 2e 35 38 20 2d 52 6f 6e 64 6f 20 76 69 76 61 63 |, Op.58 -Rondo vivac|
1230: 65 |e |
00001231 ARTIST
1231: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
1251: 41 72 74 75 72 |Artur |
00001256 ARTIST
1256: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
1276: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
1296: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
1316: 61 |a |
00001317 ALBUMARTIST
1317: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
1337: 72 72 6f |rro |
00001340 ALBUMARTIST
1340: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
1360: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00001378 ALBUM
1378: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
1398: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
1418: 69 7a 61 72 72 6f |izarro |
00001424 ALBUM
1424: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
1444: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00001457 TRACKNUMBER
1457: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 36 |…TRACKNUMBER=6 |
00001474 DATE
1474: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00001487 GROUPING
1487: 1b 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 35 38 |…GROUPING=Bn,op58|
1507: 20 43 50 20 23 34 20 69 6e 20 47 | CP #4 in G |
00001518 COMPOSER
1518: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
1538: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
1558: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00001578 GENRE
1578: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
1598: 6f |o |
00001599 TOTALTRACKS
1599: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00001616 COMMENT
1616: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
1636: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
1656: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
1676: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00001693 00140845 00139148 PICTURE
00140845 00142813 00001964 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/07 - Piano Concerto No 5 in E flat major Op 73 Emperor - Allegro.flac
Raw Data:
File size: 770106570
Sample size: 24 bit
Duration: 1190279 ms
Bit rate: 5176 kbits/sec VBR
00000042 00002206 00002160 SEEKTABLE
00002206 00002799 00000589 VORBIS_COMMENT
00002250 TITLE
2250: 48 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |H…TITLE=Piano Conc|
2270: 65 72 74 6f 20 4e 6f 2e 35 20 69 6e 20 45 20 66 6c 61 74 20 |erto No.5 in E flat |
2290: 6d 61 6a 6f 72 2c 20 4f 70 2e 37 33 20 e2 80 98 45 6d 70 65 |major, Op.73 â…Empe|
2310: 72 6f 72 e2 80 99 20 2d 20 41 6c 6c 65 67 72 6f |rorâ… - Allegro |
00002326 ARTIST
2326: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
2346: 41 72 74 75 72 |Artur |
00002351 ARTIST
2351: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
2371: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
2391: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
2411: 61 |a |
00002412 ALBUMARTIST
2412: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
2432: 72 72 6f |rro |
00002435 ALBUMARTIST
2435: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
2455: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00002473 ALBUM
2473: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
2493: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
2513: 69 7a 61 72 72 6f |izarro |
00002519 ALBUM
2519: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
2539: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00002552 TRACKNUMBER
2552: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 37 |…TRACKNUMBER=7 |
00002569 DATE
2569: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00002582 GROUPING
2582: 26 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 37 33 |&…GROUPING=Bn,op73|
2602: 20 43 50 20 23 35 20 69 6e 20 45 62 20 27 45 6d 70 65 72 6f | CP #5 in Eb ‘Empero|
2622: 72 27 |r’ |
00002624 COMPOSER
2624: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
2644: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
2664: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00002684 GENRE
2684: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
2704: 6f |o |
00002705 TOTALTRACKS
2705: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00002722 COMMENT
2722: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
2742: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
2762: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
2782: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00002799 00141951 00139148 PICTURE
00141951 00143919 00001964 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/08 - Piano Concerto No 5 in E flat major Op 73 Emperor - Adagio un poco mosso.flac
Raw Data:
File size: 227372283
Sample size: 24 bit
Duration: 364532 ms
Bit rate: 4994 kbits/sec VBR
00000042 00000712 00000666 SEEKTABLE
00000712 00001318 00000602 VORBIS_COMMENT
00000756 TITLE
756: 55 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |U…TITLE=Piano Conc|
776: 65 72 74 6f 20 4e 6f 2e 35 20 69 6e 20 45 20 66 6c 61 74 20 |erto No.5 in E flat |
796: 6d 61 6a 6f 72 2c 20 4f 70 2e 37 33 20 e2 80 98 45 6d 70 65 |major, Op.73 â…Empe|
816: 72 6f 72 e2 80 99 20 2d 20 41 64 61 67 69 6f 20 75 6e 20 70 |rorâ… - Adagio un p|
836: 6f 63 6f 20 6d 6f 73 73 6f |oco mosso |
00000845 ARTIST
845: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
865: 41 72 74 75 72 |Artur |
00000870 ARTIST
870: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
890: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
910: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
930: 61 |a |
00000931 ALBUMARTIST
931: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
951: 72 72 6f |rro |
00000954 ALBUMARTIST
954: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
974: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00000992 ALBUM
992: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
1012: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
1032: 69 7a 61 72 72 6f |izarro |
00001038 ALBUM
1038: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
1058: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00001071 TRACKNUMBER
1071: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 38 |…TRACKNUMBER=8 |
00001088 DATE
1088: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00001101 GROUPING
1101: 26 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 37 33 |&…GROUPING=Bn,op73|
1121: 20 43 50 20 23 35 20 69 6e 20 45 62 20 27 45 6d 70 65 72 6f | CP #5 in Eb ‘Empero|
1141: 72 27 |r’ |
00001143 COMPOSER
1143: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
1163: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
1183: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00001203 GENRE
1203: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
1223: 6f |o |
00001224 TOTALTRACKS
1224: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00001241 COMMENT
1241: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
1261: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
1281: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
1301: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00001318 00140470 00139148 PICTURE
00140470 00142438 00001964 PADDING
File = /Volumes/MUSIC/ FLAC/Beethoven - Piano Concertos 3, 4, 5 [Pizzaro; Mackeras-Scottish Chamber Orchestra] 24bit-192khz 5099 kbps/09 - Piano Concerto No 5 in E flat major Op 73 Emperor - Rondo Allegro ma non troppo.flac
Raw Data:
File size: 383096749
Sample size: 24 bit
Duration: 590530 ms
Bit rate: 5192 kbits/sec VBR
00001126 00001741 00000611 VORBIS_COMMENT
00001170 TITLE
1170: 5e 00 00 00 54 49 54 4c 45 3d 50 69 61 6e 6f 20 43 6f 6e 63 |^…TITLE=Piano Conc|
1190: 65 72 74 6f 20 4e 6f 2e 35 20 69 6e 20 45 20 66 6c 61 74 20 |erto No.5 in E flat |
1210: 6d 61 6a 6f 72 2c 20 4f 70 2e 37 33 20 e2 80 98 45 6d 70 65 |major, Op.73 â…Empe|
1230: 72 6f 72 e2 80 99 20 2d 20 52 6f 6e 64 6f 3a 20 41 6c 6c 65 |rorâ… - Rondo: Alle|
1250: 67 72 6f 2c 20 6d 61 20 6e 6f 6e 20 74 72 6f 70 70 6f |gro, ma non troppo |
00001268 ARTIST
1268: 15 00 00 00 41 52 54 49 53 54 3d 50 69 7a 61 72 72 6f 2c 20 |…ARTIST=Pizarro, |
1288: 41 72 74 75 72 |Artur |
00001293 ARTIST
1293: 39 00 00 00 41 52 54 49 53 54 3d 20 4d 61 63 6b 65 72 72 61 |9…ARTIST= Mackerra|
1313: 73 2c 20 53 69 72 20 43 68 61 72 6c 65 73 2f 53 63 6f 74 74 |s, Sir Charles/Scott|
1333: 69 73 68 20 43 68 61 6d 62 65 72 20 4f 72 63 68 65 73 74 72 |ish Chamber Orchestr|
1353: 61 |a |
00001354 ALBUMARTIST
1354: 13 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 50 69 7a 61 |…ALBUMARTIST=Piza|
1374: 72 72 6f |rro |
00001377 ALBUMARTIST
1377: 22 00 00 00 41 4c 42 55 4d 41 52 54 49 53 54 3d 20 4d 61 63 |"…ALBUMARTIST= Mac|
1397: 6b 65 72 72 61 73 2f 53 63 6f 74 74 69 73 68 20 43 4f |kerras/Scottish CO |
00001415 ALBUM
1415: 2a 00 00 00 41 4c 42 55 4d 3d 42 65 65 74 68 6f 76 65 6e 3a |*…ALBUM=Beethoven:|
1435: 20 50 43 73 20 23 33 2d 35 20 5b 32 34 2f 31 39 32 5d 5b 50 | PCs #3-5 [24/192][P|
1455: 69 7a 61 72 72 6f |izarro |
00001461 ALBUM
1461: 1d 00 00 00 41 4c 42 55 4d 3d 20 4d 61 63 6b 65 72 72 61 73 |…ALBUM= Mackerras|
1481: 2f 53 63 6f 74 74 69 73 68 20 43 4f 5d |/Scottish CO] |
00001494 TRACKNUMBER
1494: 0d 00 00 00 54 52 41 43 4b 4e 55 4d 42 45 52 3d 39 |…TRACKNUMBER=9 |
00001511 DATE
1511: 09 00 00 00 44 41 54 45 3d 32 30 30 39 |…DATE=2009 |
00001524 GROUPING
1524: 26 00 00 00 47 52 4f 55 50 49 4e 47 3d 42 6e 2c 6f 70 37 33 |&…GROUPING=Bn,op73|
1544: 20 43 50 20 23 35 20 69 6e 20 45 62 20 27 45 6d 70 65 72 6f | CP #5 in Eb ‘Empero|
1564: 72 27 |r’ |
00001566 COMPOSER
1566: 38 00 00 00 43 4f 4d 50 4f 53 45 52 3d 42 65 65 74 68 6f 76 |8…COMPOSER=Beethov|
1586: 65 6e 2c 20 4c 2e 56 2e 20 5b 31 37 37 30 2d 31 38 32 37 5d |en, L.V. [1770-1827]|
1606: 5b 63 6c 61 73 73 69 63 61 6c 5d 5b 47 65 72 6d 61 6e 79 5d |[classical][Germany]|
00001626 GENRE
1626: 11 00 00 00 47 45 4e 52 45 3d 37 20 43 74 6f 20 50 69 61 6e |…GENRE=7 Cto Pian|
1646: 6f |o |
00001647 TOTALTRACKS
1647: 0d 00 00 00 54 4f 54 41 4c 54 52 41 43 4b 53 3d 39 |…TOTALTRACKS=9 |
00001664 COMMENT
1664: 49 00 00 00 43 4f 4d 4d 45 4e 54 3d 5b 50 44 46 5d 2c 20 0a |I…COMMENT=[PDF], .|
1684: 52 65 63 6f 72 64 65 64 20 61 74 20 50 65 72 74 68 20 43 6f |Recorded at Perth Co|
1704: 6e 63 65 72 74 20 48 61 6c 6c 2c 20 55 4b 20 66 72 6f 6d 20 |ncert Hall, UK from |
1724: 32 7e 35 20 4e 6f 76 65 6d 62 65 72 20 32 30 30 38 |2~5 November 2008 |
00001741 00140893 00139148 PICTURE
00140893 00142861 00001964 PADDING
The Raw data of the album “Beethoven: Late Choral & Gershwin [SACD]” has more than 40K characters, so I can not post it.
If I’ll understand what I should look at, I’ll tell you what I see.
