Damien,
Is there a chance now that a workaround has been acknowledged that it can be fixed in an upcoming regular update? The sound is too beautiful, to be in experimentation mode.
Have you experienced the UI issue, where it appears Audirvana is operating in the background and not an app? You can probably tell I’m hesitant to install workarounds while the sound is so good right now.
I have not experienced the issue with it running in the background. However, I never experienced that problem with my installation, and based on Damien’s response it sounds like it is a separate issue not directly related to the original issue in this thread with regards to the freezing at startup in Artist view. I ran the application multiple times today without any issues.
Since the ‘starting as background task’ is not the main subject of this thread, I’ll start another one.
Here
https://community.audirvana.com/t/audirvana-starts-as-background-process-with-no-ui-displayed/17713
Hello @pieronip, @ljmarxen, @Partman and everyone who made the test for this issue, thank you for your test.
The fix we made is now available with the latest update we made for Audirvana 3.5.40 for Windows 10.
To be able to make the update you will need to uninstall the test version we sent to you and install the latest version using our website: https://audirvana.com/try/
Thank you.
New version installed and working perfectly.
Can you give us any insight as to thge nature of the problem? Just curiosity.
It’s a bit technical, it was a res condition that was present since a lot of time and was revealed recently. We couldn’t reproduce the issue until we had a crash report that had the exact error.
Thanks for the reply. Like everybody else here I believe the problem is solved. Life is good! Thanks again.
Beautiful again. That bugger was tough, but you and Audirvana were better. Love that sound! Thanks again.
Finally working for me…
Thanks!
Feel free to delete my pissed off comments.
