It doesn’t make a difference.
Disappointly, I must agree.
Reactived my 3.5 license, updated to 3.5.46 (now running macOS 11.4), and unfortunately no joy with upnp. Looks like that latest fix has not corrected the issue.
Also, the same issue still exists on AS 1.2.
There must be some setting in Audirvana that’s causing a problem.
No change in settings in 3.5.44 and left the same setting in 3.5.46.
The only change was the upgrade from macOS 11.3 to 11.3.1 afterwhich DLNA stopped working. Upgrade to 11.4 remained the same. (using DLNA with others apps and macOS 11.3.1 still working)
I mean there’s some setting in Audirvana that must be problematic with respect to the latest Big Sur versions. It’s not the underlying Audirvana program itself, because I can stream with no issues on 11.4.
Tried a variety of setting changes but no joy
Would you be happy to share your settings under Active Device and Upsampling. Maybe we can start to isolate the issue.
Tried to swtich off the firewall as well, but unfortunately still no joy. Press play, track loads fully, but does not start. Deleted and readded AS as well as AV under accessibilty (under Privcay and Security), but unfortunately no impact
Debug info for AS 1.2 below with UPNP issue
Audirvana Mac Version 1.2.0 (10020)
macOS 11.4.0 with 8192MB RAM
Stop band attenuation 215.892dB
Phase minimum phase
Max allowed volume: 81.0812
AUTO: /Volumes/music/
Library database path: /Users/grantbutcher/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50083
Preferred device: B&W GROUP LTD CP-800 Model UID:B&W Group Ltd CP-800 UID:uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.1.24:8080/description.xml
ID 0x0 CP-800
Manufacturer: B&W Group Ltd
Model Name:
Model UID: B&W Group Ltd CP-800
UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c
Volume control: No
http-wavetunes::audio/x-ms-wma:*
http-get::audio/x-caf:
http-get::audio/x-aiff:
http-get::audio/aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 192kHz finite length
0 physical formats
CurrentTransportStatus: ERROR_OCCURRED
NrTracks: 1
MediaDuration: 0:06:30
CurrentURI: http://192.168.1.7:49154/audirvana/audio_0.aif
CurrentURIMetadata:
dc:titleTuesday Wonderland</dc:title>
dc:creatorEsbjörn Svensson Trio</dc:creator>
upnp:artistEsbjörn Svensson Trio</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/2431c1a5/d95a/469c/84de/6d60a82aa2b2/640x640.jpg</upnp:albumArtURI>
upnp:albumE.S.T. Tuesday Wonderland</upnp:album>
nextURI: http://192.168.1.7:49154/audirvana/audio_1.aif
The Goldhearted Miner
3
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions LastChange string TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:1 SeekOnPaused,WHA urn:schemas-upnp-org:device:MediaRenderer:1 CP-800 B&W Group Ltd CP-800 Stereo Preamp Processor CP-800 CP-800 D81EDE20B93C uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-smsc-com:service:X_WholeHomeAudio:1 urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl urn:tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.1.24UPnP devices found : 1
Device #0: ID 0x0 CP-800 UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20b93c Location: http://192.168.1.24:8080/description.xml
Max. memory for audio buffers: 3726MB
Exclusive access: Disabled
Local devices found : 3
Device #0: ID 0x3c Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x38 CP-800 Manufacturer: B&W Group Ltd Model UID: CP-800:19B5:0009 UID: AppleUSBAudioEngine:B&W Group Ltd:CP-800:2144572:1 Model Name: B&W Group Ltd CP-800
Device #2: ID 0x2d WiDisplay Loopback Sound Virtual Device Manufacturer: BUGUN Software Co., Ltd Model UID: WiDisplayLoopbackSoundVirtualDevice:WiDisplay Loopback Sound Virtual Device UID: WiDisplayLoopbackSoundVirtualEngine:0 Model Name: BUGUN Software Co., Ltd WiDisplay Loopback Sound Virtual Device
We won’t be able to see anything in that output. It just gives the settings for Audirvana and the settings for receiver device. Audirvana connects to the device no problem. The problem is the actual music file it sends to it. There’s something wrong with the format or syntax that the receiving device doesn’t like. We have no way of knowing what that problem is unless we can see what Audirvana is sending. I’m not sure how to do that or if it’s even possible without debugging Audirvana on a dev machine.
The firewall is not the issue - if it was, Audirvana wouldn’t connect to your device to begin with.
First disable upsampling, turn it off, restart your thing and see.
ropieeexl
Device Type: UPnP network player
Supported PCM rates: 44.1, 48, 88.2, 96, 176.4, 192
Supported DSD rates: DSD64, DSD128
Maximum PCM Rate: 192
Maximum PCM Bitdepth: 24
Maximum DSD Rate: DSD128
Audio Channels: Stereo
DAC used as “Not MQA”
Upsampling is deactivated
Thanks for that.
Chgd settings (only diff is that my DAC does not decode DSD), rebooted all devices after changes (mac mini and pre/DAC) but unfortunately no joy. WIll have to wait for Damien to debug issues for us
Will have to stick to USB output for now.
There is a problem with the format or syntax of the file Audirvana is sending. It’s not settings dependent.
Upgraded to v1.3
Unfortunately the UPNP issue has not been resolved in this issue, and still persists in 3.5.46
@Antoine, could you advise when this issue will be looked at?
As a further test, I installed the trial version of AS onto my windows laptop. This done to eliminate the issue of whether the DLNA implementation in the Classe Preamp is an issue.
Tested UPNP connection to my Preamp using DLNA - and all works from Windows 10.
So clearly the issue is between Audirvana and latest macOS versions.
Further testing reveals the following:
macOS 11.4 - Streaming of Radio to UPNP works
- Streaming from Tidal via UPNP NOT working
Windows 10 - Streaming of Radio and Tidal working
So, for my setup it is isolated to Tidal and local file streaming via UPNP which is not working
UPnP works OK on my 11.4 MacBook Pro M1 to a raspberry Pi running Volumio.
So, after further diagnosis
Local files (from a NAS) on 3.5.46 play, but only white noise when upsampling is activated. Local track does not start at all when upsampling is deactivated.
Not sure if this will give any clues as to where the issue / conflict in the software sits.
Still no joy with UPNP after updating to AS V1.4
Will this be resolved in the next update?
Upgraded to AS 1.4.5 - UPNP still not fixed
Is this on this list of bugs to be fixed ? Comment was made by @Antoine that AS and 3.4.44 at the time had not been tested with macos 11.3
