I am really sorry for my wording, but I am really frustrated cause I like Audirvana Studio so much.
1- ok letâs start over
2- do what @bitracer suggested, cut buffer maybe 50% start there
3- post your debug so that @bitracer and the rest can see your setup
Audirvana Studio 2.1.0 (20100)
macOS 13.0.1 with 16GB physical RAM
Connected account of : xx xx
Sync list: 5 folders
AUTO: /Volumes/Music/HD
AUTO: /Volumes/Music/HD HiRes
AUTO: /Volumes/Music/HD Move
AUTO: /Volumes/Music/HD Turbobit
AUTO: /Volumes/Music/HDDiscreet
Library database path: /Users/jule/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 64315
Max. memory for audio buffers: 2132MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
AudioQuest AudioQuest DragonFly Red v1.0
Model UID:AudioQuest DragonFly Red v1.0:21B4:0082
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100043348:1
Selected device:AudioQuest DragonFly Red v1.0
Manufacturer: AudioQuest
Model name: AudioQuest DragonFly Red v1.0
Model UID: AudioQuest DragonFly Red v1.0:21B4:0082
UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100043348:1
USB Vendor ID: 0x21b4
USB Product ID: 0x0082
ID 0x65
MQA Renderer device
Stream ID 0x66 2 channels starting at 1
8 virtual formats:
8 physical formats
Device #0: ID 0x65 AudioQuest DragonFly Red v1.0
Device #1: ID 0x43 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Disconnect Tidal, restart Audirvana a see what happens.
We see he has plenty of computer and ram 16gb, I just reread the entire thread but Iâm missing that playback is bad, dropouts, freezing up ? Is it just that he doesnât like the speed report? Is it causing the internet to be unreliable in his home?
Done. Doesnât change anything
Disconnect the remote. Restart Audirvana and try again.
Where do i disconnect the remote?
Are you using the sysoptimizer?
Yes
Well, you have the answer.
Disabling SystemOptimizer doesnât helop sigh
Reboot.
Hmmm, this doesnât help, it is really a mystery, what may that be
I think itâs related to the sysoptimizer. I work all the time with Audirvana not just open but playing music.
Obviously I donât use the sysoptimizer.
Check your activity monitor, what else is loading your computer up? mds stores running amok?
What cpu?
I donât know if itâs crazy, what cpu you have?
You can try to do a clean re-install of Audirvana.
