Audirvāna Studio Feedback
Unlike Macs, PCs are cheap. You can buy a second hand i7 PC with 16 GB Ram and an SSD drive for some 200-300 Euros.
If you like the sound as you say, you may consider buying a PC on which you would run nothing else but AS to listen to your music.
Hi @Doudou,
Thanks for the reply. Yeah, I have a laptop which I can use to do as you suggest, and I may very well do that when we eventually get a remote working. But surely the point is I shouldn’t have to do that, after all I don’t have to do that with v3.5 because that does not slow down my PC like AS seems to do.
You can try to reduce the pre-load cache.
Hi bitracer,
Thanks for the reply, how do I do that?
Interestingly I changed from Kernel to Wasapi and that has made a bit of a reduction in the memory usage!
as 4 - AS screenshot
as 5 - Task manager screenshot (previously was 451MB of RAM)
Still difficult to use since now i have a terrible background noise when i stream QOBUZ files with UPNP protocol but all is fine when i play my local files .sometimes it happens also when i stream Tidal files …radio streams works 2 seconds and stop !!!..
i am lost and will return to 3;5 Audirvana classic since without any solution i will not subscribe !!
Audirvana Mac Version 1.0.0 (10000)
macOS 11.3.1 with 24576MB RAM
Connected account: jmboulley
	Per track: OFF
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by track
AUTO: /Users/jeanmarieboulley/Music
Library database path: /Users/jeanmarieboulley/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56676
HRA-Streaming: Connected as VirtualVault
Preferred device: NAIM AUDIO LTD. SALON ORDI Model UID:Naim Audio Ltd. salon ordi UID:uuid:5F9EC1B3-ED59-79BB-4530-E8C74F06A8A5
UPnP device at http://192.168.1.16:8080/description.xml
ID 0x0 salon ordi
Manufacturer: Naim Audio Ltd.
Model Name:
Model UID: Naim Audio Ltd. salon ordi
UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F06A8A5
Volume control: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/wav:*
http-get::audio/x-mpegurl:
http-get:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/x_pm_flac:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
20 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
0 physical formats
NrTracks: 1
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.1.13:49153/audirvana/audio_72.pcm
CurrentURIMetadata: dc:titlemp3, 44100 Hz, stereo, 320 kb/s</dc:title>upnp:artistmp3, 44100 Hz, stereo, 320 kb/s</upnp:artist>upnp:albumHi On Line Radio Pop</upnp:album>upnp:albumArtURIhttp://static.airable.io/82/24/367476.png</upnp:albumArtURI>http://192.168.1.13:49153/audirvana/audio_72.pcm
nextURI: http://192.168.1.13:49153/audirvana/audio_70.pcm
nextURIMetadata: dc:titleMarie (Remasterisé en 2008)</dc:title>upnp:artistVéronique Sanson</upnp:artist>upnp:albumMoi, le venin (Edition Deluxe)</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/3aea11ff/da50/4ad8/8cff/9acbeed48b9d/1280x1280.jpg</upnp:albumArtURI>http://192.168.1.13:49153/audirvana/audio_70.pcm
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001
	</pnpx:X_compatibleId>
pnpx:X_deviceCategory
MediaDevices
	</pnpx:X_deviceCategory>
pnpx:X_hardwareId
BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01
	</pnpx:X_hardwareId>
df:X_deviceCategory
Multimedia.DMR
	</df:X_deviceCategory>
salon ordi
Naim Audio Ltd.
http://www.naimaudio.com
Naim Mu-so Qb all-in-one audio player
Mu-so Qb
20-004-0024
https://www.naimaudio.com/mu-so
E8C74F06A8A5
123810928305
image/jpeg
48
48
24
/BCO_device_lrg_icon.jpg
image/png
120
120
24
/BCO_device_sm_icon.png
image/png
48
48
24
/BCO_device_lrg_icon.png
text/html
120
120
24
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
http://192.168.1.16:80/1000/index.html
<X_Rhapsody-Extension>
urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:E8C74F06A8A5
</X_Rhapsody-Extension>
UPnP devices found : 4
Device #0: ID 0x0 cuisine UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F089F01 Location: http://192.168.1.20:8080/description.xml
Device #1: ID 0x0 salon ordi UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F06A8A5 Location: http://192.168.1.16:8080/description.xml
Device #2: ID 0x0 Décodeur TV UHD UID: uuid:00ababad-7947-1048-8a00-a89a93e49af1 Location: http://192.168.1.10:42300/description.xml
Device #3: ID 0x0 Salon UID: uuid:3caf5c07-1cd4-4810-864a-68e986211a8d Location: http://192.168.1.11:42894/3caf5c07-1cd4-4810-864a-68e986211a8d.xml
Max. memory for audio buffers: 12316MB
Local devices found : 4
Device #0: ID 0xcf Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:122 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Sortie intégrée
Device #1: ID 0xbe Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #2: ID 0x37 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1 Model Name: ma++ ingalls for Cycling '74 Soundflower (64ch)
Device #3: ID 0x2c AirParrot Manufacturer: squirrels Model UID: com_squirrels_driver_AudioDevice:AirParrotSpeakers UID: com_squirrels_driver_AudioEngine:0 Model Name: squirrels AirParrot
il faut aller sur le symbole entonnoir pour avoir l éditeur de filtres et trouver les genres a sélectionner
ca devrait marcher …d 'accord avec vous …on galère …
Wow! Congrats Damien. This sound quality improvement is what i have been trying to achieve via hardware upgrades. Theres more texture, tone, separation and sustain PRAT and more. Ed.
Appart of the trial, has anyone tried to actually purchase the AS already? The web site seems to miss “buy” functionality and the links to Account Management seem to be broken. But perhaps I am missing something.
It is free now for a month. They are updating site soon
Reply to
dieterjp
When playing an album to the end, the last seconds of the last track are cut off.
Anyone else?
Dieter
This hasn’t changed since v3.5… I started the following popular thread:
Songs stop playing seconds from the end (the definitive edition) - Software User Interface Feedback - Audirvana
Audirvana has shown no signs of fixing this terrible bug, other than to say, turn off your upscaling, which doesn’t work for many nor for streaming service users.
Sigh…
merci beaucoup…fallait savoir :grinning:
Hear hear. I have been using Audirvana since before 1.5 was an upgrade. Always it has been superior to any other sort of delivery to a DAC, based on the resolution of what comes out my speakers. Now there has been an audible downturn, except perhaps for Windows users, who maybe can still find manna in their wilderness. I am enjoying 3.5 right now, listening to Joao Gilberto, and do not wish any longer to touch the Studio app, at least until Damien answers for these choices for music lovers on Mac in particular, and announces remedies. Long may the compatibility of 3.5 last with Mac OS; but I also am reconsidering my options.
In the settings change the buffer size.
After several A-B comparisons between AS n 3.5 - its like having two different dac’s . AS is aptly named - resolution and ‘audiophile’ impressive whilst 3.5 is more relaxing, warmer. I can live with both- depending on the recording.
I’m also using Audirvana since Audirvana Plus 1.5.
I did not upgrade to A 3.5, but remained with A+ 2.5, because A3.5 did not include some features that I needed, so I had to check other players.
Now I’m back to check AS.
I’m on macOS Big Sur and A+ 2.5 still runs fine. So I don’t think you should be worried with incompatibility issues in the foreseeable future.
I left Studio on overnight to complete analyzing my small 7500 tracks library. It never completed and it crashed just now. Funny that after I relaunched, it now sees most, but still not all, my UPnP endpoints.
Yeah! Works better than the mute button! :smile:
HAHAHA… You made me laugh again.
I would be very interested in hearing from the developers what changes they made in the player algorithms, especially on Mac, because to my ears it is not a subtle difference and definitely not an improvement over 3.5. I’m willing to be patient as the development team works through the debugging of what is clearly a beta version, but I have no interest in subscribing to the AS app if this is the new direction in sound quality for Audirvana.
Hey, you all are right. It is a mess and it seems that Damien has opened the can of pandora.
So much trouble with the streaming services, wow. I will postpone the Studio until better times. Today I tried amazon HD and extremeHD, both sound pretty well on my audio system, and this with the amazon application program for PCs. No Audirvana used.
Upon all of the feedback on Studio Trial it seems a big problem to handle the streaming providers within Studio. For me, let this stuff out and deliver a Studio LITE for local stored music files only. But I fear that the intention to play with the big boys will perhaps end in disaster.
