We officially start the beta-testing of the Linux and NAS (QNAP) versions of Audirvāna!
The Audirvāna Core player on Linux is headless. This means Audirvāna Studio/Origin for Linux and NAS don’t have an interface.
You’ll need the latest version of the Remote App (v 5.0) to control it. All interactions are done through the remote app, except starting the app for the Linux version.
You can install the latest version of the Remote using the links below:
When you share an issue, please make sure to share the specifications of the device you installed Audirvāna.
The NAS version for Synology should soon be ready
How to install Audirvāna on QNAP NAS
First, download your qpkg version depending on CPU architecture:
Access your QNAP GUI and open App Center.
Click on the steering wheel:
Ensure the setting “Allow installation of applications without a valid digital signature” is enabled:
Once done, please click on the + icon:
Then click Browse and select the qpkg file you downloaded. Click Install and OK.
Click on “I understand the risks and want to install this application.” then Install:
Audirvāna is now installed and started; head over to the Audirvāna Remote app to use Audirvāna!
How to install Audirvāna on Linux
First, download your version depending on CPU architecture and Linux distro:
Audirvāna Studio:
Audirvāna Origin:
After installing the package (more about it for RPM) and Debian), you’ll find the executable in /opt/audirvana/studio or /opt/audirvana/origin
To start automatically Audirvāna Studio/Audirvāna Origin as a service at boot, a shell script setAsService.sh can be found in the same folder.
Preferences file are in ~/.config/audirvana
Audirvāna database and log files are in ~/.local/share/audirvana
