Now @Antoine seems to have surfaced is there any comment on why the Cambridge Audio CXN is not working with uPNP on AS ?
There are several threads about it
I am patiently waiting for news as well. I have not contacted support directly as they must be aware of the problem as there have been so many comments on the forum.
They seem to want to blame CA âŚ
JRiver works fine with the CXN, maybe they want to lose potential users , who knows they never respond so how are we to know ?
3.5 works with CXN so I would have thought that shows they know how to make it work. I am sure that if they discussed the issue with CA they could find a solution between them. CA actively update the firmware to meet challenges. I believe now that they are taking an ongoing fee to use the software they are duty bound to fix it sooner or later.
We can hope, I have run out of trial time and I have no interest in paying a subscription for something that doesnât work with my equipment.
The only way I will even consider AS now , is when itâs fixed for the CXN I am given a further month trial to really evaluate it
Another new version today and some UPnP issues addressed - sadly not our turn yet.
YupâŚâŚ.SSDD
Hello CXN users, can you send us a copy of the âDebug Infoâ when you have the CXN selected in Studio? You can get it in Audirvana Settings>My account
The goal is to see if you have the proper settings in Studio and what do you have in common in the Debug info.
Hereâs mine , is this where you want it . I have taken off the Raw PCM flag that is how it should be and what was failing . With Raw PCM on it works after a fasion. There has just been an update to 1.5.7 which i have not tested
Current version: 1.5.7 (10507)
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 2 folders
AUTO: F:\MusicLibrary\01 - Rock
AUTO: F:\MusicLibrary\02 - Classical
Library database path: C:\Users\User\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.0.156 on port 63369
Preferred device: Cambridge Audio CXN Model UID:Cambridge Audio CXN UID:uuid:e7b2733c-e381-4797-865a-fa0ac01acfa9
UPnP device at http://192.168.0.139:8050/e7b2733c-e381-4797-865a-fa0ac01acfa9/description.xml
CXN
Manufacturer: Cambridge Audio
Model Name:
Model UID: Cambridge Audio CXN
UID: uuid:e7b2733c-e381-4797-865a-fa0ac01acfa9
8 available sample rates up to 5644800Hz
5644800
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
CurrentTransportState: TRANSITIONING
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXN Cambridge Audio http://www.cambridgeaudio.com/ CXN 2475 uuid:e7b2733c-e381-4797-865a-fa0ac01acfa9 000cc74a image/png 48 48 8 /e7b2733c-e381-4797-865a-fa0ac01acfa9/CA-roundal-48x48.png image/jpeg 48 48 24 /e7b2733c-e381-4797-865a-fa0ac01acfa9/CA-roundal-48x48.jpg image/png 120 120 8 /e7b2733c-e381-4797-865a-fa0ac01acfa9/CA-roundal-120x120.png image/jpeg 120 120 24 /e7b2733c-e381-4797-865a-fa0ac01acfa9/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /e7b2733c-e381-4797-865a-fa0ac01acfa9/RenderingControl/RenderingControl1.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/RenderingControl/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /e7b2733c-e381-4797-865a-fa0ac01acfa9/ConnectionManager/ConnectionManager1.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/ConnectionManager/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /e7b2733c-e381-4797-865a-fa0ac01acfa9/ContentDirectory/ContentDirectory1.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/ContentDirectory/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /e7b2733c-e381-4797-865a-fa0ac01acfa9/AVTransport/AVTransport1.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/AVTransport/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /e7b2733c-e381-4797-865a-fa0ac01acfa9/RecivaRadio/RecivaRadio.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/RecivaRadio/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /e7b2733c-e381-4797-865a-fa0ac01acfa9/UuPlaylist/Playlist.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/UuPlaylist/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /e7b2733c-e381-4797-865a-fa0ac01acfa9/RecivaSimpleRemote/RecivaSimpleRemote.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/RecivaSimpleRemote/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /e7b2733c-e381-4797-865a-fa0ac01acfa9/StreamMagic6/StreamMagic6.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/StreamMagic6/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /e7b2733c-e381-4797-865a-fa0ac01acfa9/SMSearch/SMSearch.xml /e7b2733c-e381-4797-865a-fa0ac01acfa9/SMSearch/invoke /e7b2733c-e381-4797-865a-fa0ac01acfa9/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 1
Device #0CXN UID: uuid:e7b2733c-e381-4797-865a-fa0ac01acfa9 Location: http://192.168.0.139:8050/e7b2733c-e381-4797-865a-fa0ac01acfa9/description.xml
Max. memory for audio buffers: 2636MB
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Realtek Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_1462FA65&REV_1003 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2baefc54-934c-4a34-94dd-9c36e7681414}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Ok, can you make some test with 1.5.7 with or without the Raw PCM option enabled?
With 1.5.7
Neither raw PCM on or off provides play.
This is how it was originally , with 1.5.5 adding with RawPCM played , its now reverted to not play !!
Setting up-sample to âDevice Maxâ allowed play in 1.5.5. now 1.5.7 doesnât play in this mode , it s worse than before !! Moving 1.5.5 to 1.5.7 has broken the up-sample work around â maybe a clue ?
AS plays to my local sound card (included on MB) but thatâs as far as I can go
My Rpi4 running Riopeee XL show as a device and plays
Good Luck !!
Here is mine. Current version: 1.5.7 (10507)
Bandwidth at 0dB = 83.8462%
Phase = 66%
Sync list: 0 folders
Library database path: C:\Users\user\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.106 on port 54687
Preferred device: Cambridge Audio CXNv2 (f3) Model UID:Cambridge Audio CXNv2 (f3) UID:uuid:8b5f1c0c-5670-430e-ab43-e4ed26394015
UPnP device at http://192.168.1.107:8050/8b5f1c0c-5670-430e-ab43-e4ed26394015/description.xml
CXNv2 (f3)
Model Name:
Model UID: Cambridge Audio CXNv2 (f3)
UID: uuid:8b5f1c0c-5670-430e-ab43-e4ed26394015
Volume control: No
Avoid RAW PCM streams: Yes
http-get::audio/:*
DLNA 1.5: Yes
Volume Control: dB
NrTracks: 1
CurrentURI:
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXNv2 (f3) Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3763 uuid:8b5f1c0c-5670-430e-ab43-e4ed26394015 00204ff3 image/png 48 48 8 /8b5f1c0c-5670-430e-ab43-e4ed26394015/CA-roundal-48x48.png image/jpeg 48 48 24 /8b5f1c0c-5670-430e-ab43-e4ed26394015/CA-roundal-48x48.jpg image/png 120 120 8 /8b5f1c0c-5670-430e-ab43-e4ed26394015/CA-roundal-120x120.png image/jpeg 120 120 24 /8b5f1c0c-5670-430e-ab43-e4ed26394015/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /8b5f1c0c-5670-430e-ab43-e4ed26394015/RenderingControl/RenderingControl1.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/RenderingControl/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /8b5f1c0c-5670-430e-ab43-e4ed26394015/ConnectionManager/ConnectionManager1.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/ConnectionManager/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /8b5f1c0c-5670-430e-ab43-e4ed26394015/ContentDirectory/ContentDirectory1.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/ContentDirectory/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /8b5f1c0c-5670-430e-ab43-e4ed26394015/AVTransport/AVTransport1.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/AVTransport/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /8b5f1c0c-5670-430e-ab43-e4ed26394015/RecivaRadio/RecivaRadio.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/RecivaRadio/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /8b5f1c0c-5670-430e-ab43-e4ed26394015/UuPlaylist/Playlist.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/UuPlaylist/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /8b5f1c0c-5670-430e-ab43-e4ed26394015/RecivaSimpleRemote/RecivaSimpleRemote.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/RecivaSimpleRemote/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /8b5f1c0c-5670-430e-ab43-e4ed26394015/StreamMagic6/StreamMagic6.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/StreamMagic6/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /8b5f1c0c-5670-430e-ab43-e4ed26394015/SMSearch/SMSearch.xml /8b5f1c0c-5670-430e-ab43-e4ed26394015/SMSearch/invoke /8b5f1c0c-5670-430e-ab43-e4ed26394015/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 2
Device #0CXNv2 (f3) UID: uuid:8b5f1c0c-5670-430e-ab43-e4ed26394015 Location: http://192.168.1.107:8050/8b5f1c0c-5670-430e-ab43-e4ed26394015/description.xml
Device #1[TV]UE40D6500 UID: uuid:e34c8638-7d30-288f-f6d3-4ece9317f293 Location: http://192.168.1.66:52235/dmr/SamsungMRDesc.xml
Max. memory for audio buffers: 2254MB
Device #0: Speakers (CA CXN USB Audio 2) Manufacturer: Microsoft Model UID: USB\VID_22E8&PID_CA02&REV_0326&MI_00 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{8816416d-1465-4d21-bfa6-eb4e05fd53e2}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: CA CXN USB Audio 2
Device #1: Speakers (2- High Definition Audio Device) Manufacturer: Microsoft Model UID: HDAUDIO\FUNC_01&VEN_111D&DEV_76D9&SUBSYS_103C183F&REV_1001 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2ffc123b-920e-4ab3-a46c-9a9857c7e56a}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
This is in DNLA mode
Phase = 66%
CXNv2 (f3)
Model Name:
Volume control: No
http-get::audio/:*
DLNA 1.5: Yes
Volume Control: dB
NrTracks: 1
CurrentURI:
nextURI:
PlayMedium: NONE
Hi Mike and Damien, today I have been able to get music playing through the CXN via UPnP. I did a computer re-boot and I had to set the CXN in network standby mode manually, use 1.5.7 and the raw workaround. It worked for all resolutions BUT the controls (pause etc) still do not work. The âloading first trackâ worked and the cover art and data showed on the CXN screen. It may not be stable (as I did manage most of this once before) but I will try a whole album and report on sound quality later. Maybe you could give it a try too?
My trial period is about to expire so I have given up and uninstalled so I cannot try it at this stage
Globally: ON
Phase = 66%
Max allowed volume: 95.8263
Replay Gain: by track
Sync list: 31 folders
AUTO: /Volumes/music/A/ACDC/Back In Black 128 DSD
AUTO: /Volumes/music/B/Bob Marley & The Wailers/Studio albums/Bob Marley & The Wailers - Kaya (1978) (Remastered 2018)
AUTO: /Volumes/music/B/beatles/White Album DSD 128
AUTO: /Volumes/music/C/Chris Rea/The Road To Hell -DSF 128
Manual: /Volumes/music/C/Clash/Give 'Em Enough Rope -96-24
AUTO: /Volumes/music/D/Daft Punk/random access memories DSD 128
AUTO: /Volumes/music/D/Deep Purple/Burn 128 DSD
AUTO: /Volumes/music/D/Deep Purple/Fireball DSD 128
AUTO: /Volumes/music/D/Deep Purple/In Rock DSF 128
AUTO: /Volumes/music/D/Deep Purple/Machine Head - DSD 128
AUTO: /Volumes/music/D/Dire straits lossless/Dire Straits DSD
AUTO: /Volumes/music/E/Eagles - discography/Greatest Hits DSD -128
AUTO: /Volumes/music/I/Interpol/Turn on the Bright Lights-DSD 128
AUTO: /Volumes/music/J/Joy Division/Closer- DSD 128
AUTO: /Volumes/music/J/Joy Division/Unknown Pleasures -DSD 128
AUTO: /Volumes/music/M/Marillion/Fugazi - DSF 128
AUTO: /Volumes/music/M/Metallica/And Justice For All DSD 128
AUTO: /Volumes/music/M/Metallica/Metallica Metallica
AUTO: /Volumes/music/P/Prodigy/Music For The Jilted Generation -DSD 128
AUTO: /Volumes/music/P/Prodigy/The Fat Of The Land-DSD 128
AUTO: /Volumes/music/Prince/PRINCE STUDIO ALBUMS/Purple Rain DSD 128
AUTO: /Volumes/music/Q/queen lossless/A Kind Of Magic - 2 CD Remastered Deluxe Edition-2011
AUTO: /Volumes/music/Q/queen lossless/Innuendo-DSD 128
AUTO: /Volumes/music/R/Rage Against The Machine/Rage Against the Machine-DSD 64
AUTO: /Volumes/music/S/Santana/Abraxas - 176kHz FLAC
AUTO: /Volumes/music/S/Stray Cats/40 DSD 128
AUTO: /Volumes/music/S/Stray Cats/Built for Speed DSF 64
AUTO: /Volumes/music/T/T.Rex - 2014 - The Albums Collection (10CD Box Set Edsel Records)/Electric Warrior DSD 64
AUTO: /Volumes/music/U/U2/Songs of Innocence
AUTO: /Volumes/music/Z/ZZ Top/ Special - 1985 - Promo, DSF 128
AUTO: /Users/budgie/Music/Whoâs Next dsd 128
Library database path: /Users/budgie/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 54704
Preferred device: CAMBRIDGE AUDIO BUD Model UID:Cambridge Audio Bud UID:uuid:20cb3889-4f5d-4321-be97-df75eb43b92b
UPnP device at http://192.168.1.67:8050/20cb3889-4f5d-4321-be97-df75eb43b92b/description.xml
ID 0x0 Bud
Model Name:
Model UID: Cambridge Audio Bud
UID: uuid:20cb3889-4f5d-4321-be97-df75eb43b92b
7 available sample rates up to 2822400Hz
Volume control: No
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/3gpp:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/:*
DLNA 1.5: Yes
Volume Control: dB
11 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
CurrentURI:
nextURI:
PlayMedium: NONE
<?xml version="1.0"?>1
0
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
STOPPED
TransportStatus
string
OK
string
NONE
RecordStorageMedium
string
NOT_IMPLEMENTED
string
string
NOT_IMPLEMENTED
CurrentPlayMode
string
NORMAL
NORMAL
TransportPlaySpeed
string
1
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
NumberOfTracks
ui4
0
CurrentTrack
ui4
0
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
LastChange
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
ABS_TIME
string
ui4
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
SetAVTransportURI
InstanceID
in
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
RecordMedium
out
RecordStorageMedium
WriteStatus
out
GetTransportInfo
InstanceID
in
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
TrackMetaData
out
TrackURI
out
CurrentTrackURI
RelTime
out
AbsTime
out
RelCount
out
AbsCount
out
InstanceID
in
PlayMedia
out
RecMedia
out
RecQualityModes
out
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
InstanceID
in
Actions
out
0
Bud
Cambridge Audio
CXNv2
3763
00206a15
image/png
48
48
8
/20cb3889-4f5d-4321-be97-df75eb43b92b/CA-roundal-48x48.png
image/jpeg
48
48
24
/20cb3889-4f5d-4321-be97-df75eb43b92b/CA-roundal-48x48.jpg
image/png
120
120
8
/20cb3889-4f5d-4321-be97-df75eb43b92b/CA-roundal-120x120.png
image/jpeg
120
120
24
/20cb3889-4f5d-4321-be97-df75eb43b92b/CA-roundal-120x120.jpg
/20cb3889-4f5d-4321-be97-df75eb43b92b/RenderingControl/RenderingControl1.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/RenderingControl/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/RenderingControl/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/ConnectionManager/ConnectionManager1.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/ConnectionManager/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/ConnectionManager/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/ContentDirectory/ContentDirectory1.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/ContentDirectory/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/ContentDirectory/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/AVTransport/AVTransport1.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/AVTransport/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/AVTransport/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/RecivaRadio/RecivaRadio.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/RecivaRadio/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/RecivaRadio/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/UuPlaylist/Playlist.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/UuPlaylist/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/UuPlaylist/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/RecivaSimpleRemote/RecivaSimpleRemote.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/RecivaSimpleRemote/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/RecivaSimpleRemote/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/StreamMagic6/StreamMagic6.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/StreamMagic6/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/StreamMagic6/event
/20cb3889-4f5d-4321-be97-df75eb43b92b/SMSearch/SMSearch.xml
/20cb3889-4f5d-4321-be97-df75eb43b92b/SMSearch/invoke
/20cb3889-4f5d-4321-be97-df75eb43b92b/SMSearch/event
<dlna:X_DLNADOC xmlns:dlna=âurn:schemas-dlna-org:device-1-0â>DMR-1.50</dlna:X_DLNADOC>
<dlna:X_DLNADOC xmlns:dlna=âurn:schemas-dlna-org:device-1-0â>M-DMP-1.50</dlna:X_DLNADOC>
Device #0: ID 0x0 Bud UID: uuid:20cb3889-4f5d-4321-be97-df75eb43b92b Location: http://192.168.1.67:8050/20cb3889-4f5d-4321-be97-df75eb43b92b/description.xml
Max. memory for audio buffers: 16660MB
Local devices found : 5
Device #0: ID 0xec Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:122 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x38 Hue Sync Audio Manufacturer: Philips Lighting B.V. Model UID: AudioDriverPluginDevice_ModelUID UID: AudioDriverPluginDevice_UID Model Name: Philips Lighting B.V. Hue Sync Audio
Device #2: ID 0x54 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #3: ID 0x5f Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1 Model Name: ma++ ingalls for Cycling '74 Soundflower (64ch)
Device #4: ID 0x2f AirBeamTV Audio Manufacturer: AirBeamTV B.V. Model UID: AirBeamTVDevice_ModelUID UID: tv.airbeam.audiodriver_v2_2 Model Name: AirBeamTV B.V. AirBeamTV Audio
Hi Damien, I see that you have had âbug infoâ from three of us and wonder if you have been able to see the problem. However, as I reported earlier I have now succeeded in using DNLA to listen to Qobuz via SA. It has worked for 3 days and several albums streamed without a glitch. Sound quality is similar to a usb connection and is thus very good. The controls for pause, repeat, shuffle etc still do not function on DNLA but ok with usb. The âgo to next trackâ button works. The problem with tracks stopping before the end and going on to the next track is still there but I can only reproduce it on one album. It seems to be independent of âamount of memory allocated to preloadâ. I have also played 16.44 tracks which now work fine. Also upsampling works without stopping before the end of the track. Note: I use the CXN V2 in ânetwork standbyâ mode which automatically starts the player when it detects an incoming stream. I hope this helps.
My trial expires In 2 days , hardly worth the effort after 2 months of trying to get a fix , NOTHING
I really donât know what to suggest. I am certainly not going to pay a sub to check if AS works !!
Maybe a trial extension may be forthcoming , the we need to fix the iPad connection issue, every time I weaken and decide to give AS another chance I get a connection failure
@Antoine itâs really quite a poor show âŚ
I find something which can make my Edge NQ able to use UPnP to play music from AS
The trick is before using AS, play any music from CAâs streammagic apps, once play you can stop it. Then open AS and start play musicâŚIt works!!
I will use this trick until AS or CA fix the issue and my trial end⌠But be frank, I donât think AS worth me to pay for it at this momentâŚeven the SQ is better than Roon, but itâs too buggy⌠(Except UPnP, another bug is I canât pause song from the apps, I need to use the Edge remote to do it).
No offence meant but why should we have to mess around like that to make a piece of paid software work . I would have expected a piece of software that selects uPNP as its chosen transport system should work out of the box.
Its not as if Cambridge Audio is an unknown streamer technology , given that 3.5 worked and still works fine.
The release in my opinion was premature and we are expected to âworkaroundâ while the developer sorts out his bugs.
Sorry @Damien , I am a retired certified MS developer , I know its a complex development but I personally would be embarrassed.
