I just ajusted my text file for enabling Direct Mode in High Sierra (working already with beta) from the Sierra one.
Since Onyx is not yet ready for repairing the permissions after the replacement of the .ktext,
there is a new workaround… Thanx again katsu
I’m sticking to El Cap because1) I’m lazy, and 2) direct mode makes such a significant improvement in imaging, clarity, and overall sound quality.
I assume that somewhere in the MacOS driver data chain there is an integer-floating point-integer conversion step? I can’t imagine anything else that would cause non-direct mode to be so much of degradation (hear the same thing with tidal app, Roon app… nothing is like direct mode).
Feeding a Mytek Brooklyn DAC from a mac mini. But head the same thing with a Bottlehead DAC also.
After pasting the three lines command in terminal and entering the password I supposed it was been an error:
chmod: sudo: No such file or directory
chmod: chown: No such file or directory
chmod: -R: No such file or directory
chmod: root: No such file or directory
but I followed the whole instructions and now have again direct mode
Now I am on High Sierra (10.3.3 Beta 17D29a) and A+ 3.2.4, and the sound quality of SoX is excellent! Everything is working fine. I deeply thank Damien for this improvement.
By the way, even with SoX, “Direct Mode ON” does sound much better .
Thank you, Glad to help you…
i’m on it also, A+ last, running 10.13.3 that is much better then 10.13.2
while running an headless MacMini from an old iMac on 10.11.6 with screen sharing
