I’d like to add a warning about exporting playlists …
As many I faced this duplicate issue and I had to follow this procedure and I exported my playlists as recommended.
I could import every smart playlist, but regular playlist were impossible to import . I am now only using smart playlists , just to be sure I can restore them in the future.
This is quite a constraint : I need to tag albums and create smart playlists selecting the appropriate tags to create the playlists I expect …
Happy new year everyone!
I have been battling the duplicates issue since moving to 3.5+. Editing library with Audirvana shut down has appeared to help, but don’t believe it removes the problem.
Suggestions made on by others - not editing adding or deleting files whilst Audirvana is running, backing up fresh libraries and playlists has helped.
But like others, I have found it a most frustrating experience. I am spending so much of my time managing the duplicates issue that it detracts from the joy of the music.
I have used Audirvana since it was freeware - only testing a few other apps along the way. Damien has provided me with the best bang for my buck in the business. I can’t thank him enough for that.
But I now wonder about about alternatives now as look to replace my 2010 mac mini.
I am eager to find solutions to this beyond ongoing management. I can send my library file if that helps.
luke
Hello Odelay,
Have you tried what i wrote up there for doubles… i play everyday with my database adding new downloads, music is playing at the same time, no worries, no doubles, JRiver can be open also for editing what is more troubleshoot for Audirvana tags sometime… the changes i do in one soft also changes in the other as tags are written on files…
So start fresh for 2020
i don’t use iTunes or streaming devices, so maybe that can brings doubles sometimes… but doing the recipe under here, will clear them for sure, it bring back you database as new…
Big text, but fast doing it…
If you have Playlists that are important export them first to desktop and save them in a folder… when Audirvana is reset, you can re-import them back in one shot. sadly to this day, the folders they were in if so, are not back, you have to do them again…
Before doing this, maybe you should not connect after deleting those files to Roon, Tidal or others… Install Audirvana alone with your database… if working, log to Roon or else after.
Delete your music folder(s) in your Audirvana preferences window with minus sign…
Close Audirvana.
Trash All the files in that folder (that is your database of music, back it up! or not).
Restart MAC.
Open Audirvana, choose a library music folder and LET IT GO, even better don’t try to adjust windows or edit files, even playing music while it is not finished… you’ll see the progress bar going… Could be long the first time depending on how large your library is, and MAC is fast or not… go to sleep if it is too long ! Then when sync is finished, shut down Audirvana, yes, close it before playing a song… that way, you will have your database new from scratch saved without crashing or with doubles.
Then copy the .sqlite file to somewhere else from that folder…
as a backup in a folder like dated as today, then open Audirvana.
Like that, if you enter a bug you can always close Audirvana, put the latest perfect backup .sqlite in the same folder, and restart mac, then Audirvana… you’ll be at that latest backup… if you have put something else there or edit songs in between, it will sync the new files, but you will only lose your play counts of those files played in between backups.
thanks once again RunHomeSlow. I realise these posts are being duplicated a little here on AS. As I tried to say, I have been following much of the advice I have read on this issue. Someone suggested it may be a NAS related issue. I have been having some issues with my Synology NAS (and my old Mac mini may be struggling with the library - which is only 28k of tracks).
It appears that these duplicate issues are pretty rare. But those suffering are naturally keen for a fix. So I appreciate Damien and co. looking into it - it’s much appreciated
Hello @Odelay, can you send us a copy of your squlite database to this mail address : support@audirvana.com?
This is my second trial of Audirvana and must admit this time i will commit to purchasing . Simply put when it works it sounds pretty good especially with FLAC files . Heads above more feature rich platforms
However ,the duplicating of files is annoying , during this trial period its happened at least 3 times . While I worked on a fix you lose playlists and reading this thread , it seems adding files while the program is open has something to to do with this bug .
Great to be part of the Audirvana community ,
Welcome @harrystellus , I fully agree with you. As a music lover , sound comes first , cosmetic comes second …
I may say that I now have a very stable configuration and I’m using Audirvana every day with no problems since many years .
With time I guess we learn how to avoid its little bugs … for example I followed RunHomeSlow’s advice which are always very useful, I discovered that exporting then re-importing regular playlists didn’t work for me (?) so I replaced all my playlists with "smart " playlists . I can now export and re-import them with no pb anymore, just in case I need to rebuild the Audirvana data base again .
I think i have sorted my duplicates issue.
It was my NAS, not Audirvana that was responsible.
Someone from Damien’s team suggested it might be related to my Synology.
After chasing a number of red herrings, it was re-indexing my ‘music’ folder that seemed to fix it.
If you think you might have this issue:
- Go to Control Panel > Indexing Service > Media Indexing …
- https://www.synology.com/en-uk/knowledgebase/DSM/help/DSM/AdminCenter/application_mediaindexservice_general
Thanks to those there who offered suggestions - and to the smart cookie from Audirvana. Now I can sit back and enjoy the good sound. Thank you Damien and co.
Hi @Damien
I am a big supporter auf Audirvana. I use it on macOS and Windows, I also use the iOS remotes. I love the look, the sound, the concept, everything. But the issue with the duplicates (meanwhile I have lots of songs 4 times and more) bug is really starting to kill the joy in listening to music with Audirvana for me. Also, I did not hear back from you in our email thread about the issue.
All I’d like to ask for now is whether or not you guys are actually working on this and are trying to fix it. Because if not (for whatever reason) I will sadly have to find an alternative to Audirvana, I guess.
Many thanks for your reply and all the best!
Amadeus
Seemingly endless quirks, eg. duplicates, make Audirvana
a buggy mess. iTunes mode works well most of the time, despite mysterious periodic glitches with Audirvana. I meticulously maintain my library and metadata. Developer will blame the end user.
fwiw, the duplicate tracks issue I was seeing doesn’t seem to manifest on my main Windows machine. In both cases it was occurring, it was because I had multiple catalogs stored on different network drives. Having one true source of music files seems to eliminate this problem.
@sump welcome to the forum. I think you’ll find Audirvana quite reliable once you understand it. Granted, with the great variety of machine configurations, audio interfaces and storage systems, there are a lot of variables at work. If you’re having an issue, describing the problem usually will get you a reasonable answer.
Same problem here. Deleting and reloading the database (in Audirvana Application Support file) does the trick. Also realise that stopping an album playback doesn’t remove the tracks of the album from the current playlist. So if you stop playback before the end of the album, and then later choose the album again for listening, A+ load a new set of tracks on the same list, doubling each track. It is as if the Stop button act as a Pause button. My two cents !
No, on the desktop app. I’ve been noticing this for the last couple of months or so.
Can you check the integrity of your database using the check button in Audirvana settings under Maintenance?
If the integrity is ok can you make a video of the issue you have?
I am experiencing the same thing. I guess there is a problem with hashing of the files in the database which causes the dups.
I’ve been experiencing this problem since moving to 3.5.32. Duplicates used to be an issue in 2 but this was resolved. I’m using a very simple setup. A Mac mini running 10.11.6 with an external hard drive running over USB. Nothing crazy.
And still these very annoying duplicate tracks!
- I can’t erase the duplicates as the delete track option is greyed out.
- I’ve tried removing the albums and returning them. Situation gets WORSE not better.
- I’ve removed albums with three duplicates tracks, closed down Audivarna, returned them while its closed and reopen… with FIVE duplicate tracks.
Damien3… this is a fundamental problem. Are you working toward a fix???
Damien, I think that this information might be useful. I’ve been having the same difficulty. Duplicates showing up in my library.
Background – I keep my music database on two 1TB Samsung SSDs and haven’t used iTunes integrated mode since version 3.0. My amp was in for repair in January, and I took this opportunity to clean up my music files. There were not many partials or duplicate albums on the SSDs. I cleaned up the multi-disc albums by putting the individual CD rips in subfolders labeled Disc 1, Disc 2, etc. This worked well Many of the tracks that predated Audirvana were downloaded from iTunes. I took the opportunity to convert these .m4a files to uncompressed formats using dbpoweramp rather than iTunes.
Anyway, the amp came back but my ancient MBP’s HD died soon after. I ended up replacing it with a new MAC mini, DLing a fresh copy of Audirvana, attaching my SSDs, and going from there. Duplicate copies of my albums were soon showing up in the Audirvana library. Anyway, I didn’t see a need to follow RunHomeSlow’s advice on cleaning the User Account Home Folder, because new computer – fresh DL, but I did start removing my libraries before shutting down Audirvana.
All this is prelude to what I observed last night. Before shutting down my computer, I performed the recommended database maintenance. There were no issues, the three steps took under a minute, so I continued by removing the 2 SSDs from the Audirvana library before closing the program.
I then attempted to shut down my MAC mini, Apple appeared on the screen asking if I really wanted to shut down because it was busy uploading my music library to their cloud. Could the iCloud was the source of the duplicates. This may mean the dups are more ghosts from the iCloud than duplicates on my SSDs. (Many of my ghosts are CD rips rather than iTunes DL) I Hope this long description helps.
Just to clarify, from my end there is no iCloud connection and the issue persists.
