Audirvana 3.5.12
Sync list: 6 folders
AUTO: Y:\Music\24SOS
AUTO: \RN314\Audio\Music\24bit
AUTO: \RN314\Audio\Music\APhile
AUTO: \RN314\Audio\Music\APhile2
AUTO: Y:\Music\LL
AUTO: \RN314\Audio\Music\LL2
Library database path: C:\Users\LJA\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 10024MB
Local Audio Engine:ASIO 2 driver version 1106
Topping USB Audio Device
Model UID:Topping USB Audio Device
Topping USB Audio Device Manufacturer:
Model UID:Topping USB Audio Device UID:Topping USB Audio Device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Local devices found : 5
Device #0: ASIO 2.0 - ESI Juli@ Manufacturer: Model UID: ASIO 2.0 - ESI Juli@ UID: ASIO 2.0 - ESI Juli@
Device #1: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
Device #2: DSD Transcoder (DoP/Native) Manufacturer: Model UID: DSD Transcoder (DoP/Native) UID: DSD Transcoder (DoP/Native)
Device #3: foo_dsd_asio Manufacturer: Model UID: foo_dsd_asio UID: foo_dsd_asio
Device #4: Topping USB Audio Device Manufacturer: Model UID: Topping USB Audio Device UID: Topping USB Audio Device
UPnP devices found : 4
Device #0[TV] UN55JS8500 UID: uuid:19885906-4883-41d7-b464-2429022365df Location: http://192.168.1.167:9197/dmr
Device #1[BD]F5900 UID: uuid:0b532b81-00be-1000-a14f-0c89108d6275 Location: http://192.168.1.55:7676/smp_14_
Device #2AFTB@ES(192.168.1.97) UID: uuid:2ab45d7f-6916-6d98-0000-000038b27980 Location: http://192.168.1.97:52046/dev/2ab45d7f-6916-6d98-0000-000038b27980/desc.xml
Device #3AFTMM@ES(192.168.1.223) UID: uuid:79c58df6-9be3-2435-0000-000038b27980 Location: http://192.168.1.71:38419/dev/79c58df6-9be3-2435-0000-000038b27980/desc.xml
