Computer: MacBook Pro (Retina, 15-inch, Mid 2015)
maOS High Sierra version 10.13.6
Audirvana 3.5.50 (3580)
After the latest update, I am experiencing seemingly random failures to stream files which have been performing correctly before the update. Some TIDAL files play normally but others attempt to load but eventually return an error code about being unable to play file. There is no pattern with some existing playlist and files working and other failing. New files or playlist don’t seem to work at all.
I have signed out and back in with TIDAL in Audirvana with no improvement.
Can you help with solving this issue so that I can once again access TIDAL as was possible before 3.5.50?
Thanks,
Jim H.
Here is my configuration file:
macOS 10.13.6 with 16384MB RAM
Registered to James Hanesworth
Sync list: 16 folders
Manual: (OFFLINE) /Music
AUTO: /Users/jimhanesworth/Documents/_Unfiled/SkullCandy Demo Tracks/SkullCandy Demo Tracks-Original Formats
AUTO: /Users/jimhanesworth/Music/2L
AUTO: /Users/jimhanesworth/Music/Aarick Behr
AUTO: /Users/jimhanesworth/Music/Acoustic Sounds Super HiRez
AUTO: /Users/jimhanesworth/Music/Cat Stevens-DSD Double Rate Files/Tea For The Tillerman - DSD
AUTO: /Users/jimhanesworth/Music/Chesky HR
AUTO: /Users/jimhanesworth/Music/HDtracks
AUTO: /Users/jimhanesworth/Music/Linn Records
AUTO: /Users/jimhanesworth/Music/Music Glue
AUTO: /Users/jimhanesworth/Music/Oppo
AUTO: /Users/jimhanesworth/Music/Passacaglia 301 c-moll BWV 582
AUTO: /Users/jimhanesworth/Music/ProStudioMasters
AUTO: /Users/jimhanesworth/Music/Society of Sound
AUTO: /Users/jimhanesworth/Music/Sound Liaison
AUTO: /Users/jimhanesworth/Music/iTunes/iTunes Music
Library database path: /Users/jimhanesworth/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4000MB
OPPO UDP-205 USB AUDIO 2.0 DAC
Model UID:OPPO UDP-205 USB AUDIO 2.0 DAC:22D9:0461
UID:AppleUSBAudioEngine:OPPO:OPPO UDP-205 USB AUDIO 2.0 DAC:14200000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Hog Mode is on
ID 0x5b OPPO UDP-205 USB AUDIO 2.0 DAC Manufacturer:OPPO
Model UID:OPPO UDP-205 USB AUDIO 2.0 DAC:22D9:0461 UID:AppleUSBAudioEngine:OPPO:OPPO UDP-205 USB AUDIO 2.0 DAC:14200000:1
MQA Decoder device
Stream ID 0x5c 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 6
Device #0: ID 0x44 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x4e DisplayPort Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutputDP:0,1,0,1,2:0:{AC10-A0BF-3138304C}
Device #2: ID 0x28 USB audio CODEC Manufacturer: Burr-Brown from TI Model UID: USB audio CODEC:08BB:2912 UID: AppleUSBAudioEngine:Burr-Brown from TI:USB audio CODEC:200000:1
Device #3: ID 0x5b OPPO UDP-205 USB AUDIO 2.0 DAC Manufacturer: OPPO Model UID: OPPO UDP-205 USB AUDIO 2.0 DAC:22D9:0461 UID: AppleUSBAudioEngine:OPPO:OPPO UDP-205 USB AUDIO 2.0 DAC:14200000:1
Device #4: ID 0x32 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #5: ID 0x56 John’s JBL Flip Manufacturer: 57 Model UID: 57 23 UID: fc-a8-9a-db-e5-21:output
UPnP devices found : 3
Device #0: ID 0x0 O UDP-205-2 UID: uuid:b2dfac48-1dd1-11b2-aa7f-a14b2616f07b Location: http://10.0.1.60:49152/dmr_oppo.xml
Device #1: ID 0x0 [TV] Kitchen UID: uuid:08583b02-008c-1000-8d84-c4576e9561cd Location: http://10.0.1.15:7676/smp_14_
Device #2: ID 0x0 OPPO UDP-205 UID: uuid:77eeffbc-1dd2-11b2-b651-df81ad677c6b Location: http://10.0.1.64:49152/dmr_oppo.xml
